Are you tired of busting your nuts? *LINK*
Alan DuBoff
>Well, I'm talking about saw-nuts.
The traditional way was to use split-nuts, which continue on for tradition sake, if for nothing else, and they look way kewl...
Well, I have been pondering for some time on coming up with a saw nut that would allow more purchase, and allow one to get a better grip on the nut itself. What we find is that most all vendors used different sized split-nuts, and this is true to this day even. The Wenzloff saw-nuts are different than the LN, than the Adria, than the Grammercy, etc...and sometimes it requires one files a special nut driver.
I'll put a link to McMaster-Carr for the spanner screwdriver bits, I like the idea of incorporating the notched spanner screwdriver into the split-slots. A friend is working on a proof of concept.
So, I have been pondering over this, and am working with a friend to add some small pin holes or elongated slots in the bottom of the splits. My friend thinks this is worthy to patent, but I honestly do not see enough of these being used/sold to warrant such a patent, and think it would be better to just share these ideas with other makers, rather than fighting over patents as has plagued us for a century and a half...
The idea was that if it was possible to get the same look of the split-nut, but allow the use of a special spanner type bit, it would allow for much better purchase and/or abiltity to loosen/tighten in the future, since this is actually where most nuts become damaged.
For most all vintage saws, I would prefer to have an old vintage nut, should they become destroyed, but for new saws an improved split-nut would be a welcome addition to my toolmaking, speaking for myself.
I've thought about either hex or allen head as well, and another thought that had crossed my mind would be to keep the center bolt end down inside and create a hex inset around the bolt, so that you could use a hex/allen driver and not be interfered by the center bolt. That would have a different look though, and keeping the traditional look would be one of the intentions, if possible.
In this regard, either pins or slots in the bottom of the split slots seems like it may work. I have been pondering on making a thicker nut so work that idea with.
Any other comments? Traditional split-nuts best????
Remember, the saw-nuts you save from being busted could be your very own!;-)
Spanner screwdrivers at McMaster-Carr
