how flat is flat enough
RobRing
>I posted this originally in the general message board, but the concensus was that the topic might stir up a bit more traffic (if not agreement) over here.
I have a stanley #7 plane whose sole I need to flatten. I acquired it sight-unseen. I wouldn't have paid for it if I had a chance to check the flatness - buyer beware. But now I have it so use it I must! The length of the plane far exceeds my usual flattening surface, so I thought I'd use a spare cast iron table saw wing I have. Of course, it's not perfectly flat either. The wing is 27" X 10". Across the width from top to bottom it's as flat as it needs to be (within 0.001"). Along the length it ranges from a .002" dish in the center of the wing to a .004" dish near each edge. diagonally it's dished .003" along one diagonal and .004" along the other. I try to avoid being so obsessive about applying machining-type tolerances to my woodworking, but in this case it's technically metal working. Is this flat enough to use as a flattening surface for the plane? I can have the wing precision surface ground at a local shop for $40, but I'm not sure if it's worth the trouble.
Thanks,
Rob
