THE WOODRAT IS BACK!
"Peening" anvil . . .
steve mackay
>After trying to peen over a lateral adjuster lever mounting, been on the lookout for a small face somthing that I could use for other small jobs. Found this diving and it'll fit the bill. 1.5" x 19.0". Question is how to hold it on end (threaded end ). I figure cement is out. Over time I'd beat the bottom out of it. Would you think a hole bored into the end of a handy sized log ? Maybe band the log also. I could replace the log holder pretty easily. Thoughts ?
Re: "Peening" anvil . . .
Jack Guzman from Maine
>Steve,you said that was threaded? Why not tap a corresponding female thread into a thick chunk of steel as a base.---Jack
Or, if you're lucky and the threads work
Bill Houghton, Sebastopol, CA, 4" rain/24 hou
>re-tapping a pipe floor flange to fit the threads, and screwing the flange to a chunk of wood.
The big chunk of steel's probably best, though; and shouldn't be hard to find at a junkyard (or diving in the right place...).
Do you have a friend who can weld?
Marv
Alan DuBoff
>Steve,
What about building a base out of 2x10, stacked on end, or even 2x4 will work, I built one anvil stand like that, and use a stump for another anvil. A stump would be good if you have the space.
2x4 screwed together works fine, but 2x10 is more convenient. You could nail it also, then just drill a hole in the center a tad smaller than the arbor you have, or whatever that is (it looks like it was key'd) and tap it in with a small sledge. Would hold it nice and solid. The problem is that for an anvil you want the height specific, but for peening, it shouldn't be a big deal. What are you peening.
The other thing you can do is just build a smaller wood holder that can be used in a vise, and toss it in your face vise when needed to use. That would require a bench that was stable enough to peen on, as well as a vise that could sustain that type of work also.
Really depends on your space limitations.
paul womack
>I know the proper smiths will look down, and say there's no substitute for a proper anvil, but I get a lot of small jobs done using a 14Lb sledge hammer head (polished face) held in a big vise.
Hammer faces are hardened, and 14Lb is enough for small (cold) tasks - I don't have any metal heating facilities outside my kitchen gas hob.
BUgBear
Alan DuBoff
>'Bear said:
"I know the proper smiths will look down"
Since I mentioned a similar way, I guess that classifies me as less than proper smith...:-/
I think the sledge is a great idea, and in some ways might be better than the smaller arbor in this thread, but since he has it...
I think it would be possible to use about 4 lengths of 2x4, glue them together in a 3 ft length, and have that sitting on the floor, with the steel arbored pic'd in this thread, and clamp it into a face vise. If done correctly, the 2x4s would take the bulk of the impact, and the vise would be left alone for the most part.
I think that would be a fairly easy way to secure it.
Re: "Peening" anvil . . . *LINK*
BobStrawn
>In ancient times, a small portable anvil for peening was quite common. If you look up scythes, you will find that portable anvils are still in use and available for sale. This is still considered a proper and preferred treatment for sharpening/hardening fine scythe blades.
A common southern oak called the post oak, was at onetime considered the best mount for an anvil. It is one of the heavier oak woods, so perhaps that was one of the reasons. If you live in the south, it should be fairly easy to get a long enough section of post oak. It is generally disposed of as a trash wood.
Bob
Scythe Peening
Todd Hughes
>I guess there are all kinds of complicated and time consuming ways to do this but when I use things like this for peining I always just put a piece of scrap leather around it and put it in my vice with the bottom resting on the screw housing. Ain't like you going to be hitting it with a big hammer eh? Never had any trouble and never gave it much thought that it should be more complicated or that I needed to build somthing special....somtimes when I wasn't so particular I would leave out the leather.....Todd
Todd, yep, that's what I do...keep it simple..
Marv
agree... KISS... The leather is a bit much though
Parisian, VL
It is true, simple is good...
Alan DuBoff
>But I personally don't like to clamp and do any hammering on some of my woodworking vises, and especially don't like to clamp any type of peening device made out of round metal in any with a wooden jaw, or one that is lined with leather. Wrapping the pin in leather might help some, but I would still use a metal vise.
Peening is horses for courses, and simple certainly is best, which is why I would just peen on the top of a post vise. One of the smithys I frequent occasionally has 2 post vises at the forge I use, one up high for twisting/hot-filing and another down lower for stamping and/or hammering. I have peened on the top of the lower vise with no problem, doesn't even require any securing, go figure. For that matter, an anvil does work for peening also, for *me*. I have a couple post vises at home also, so no problem.
Given the options, I'll spare my woodworking vises with wood/leather jaws on them. I picture an old cabinet maker's bench in your shop that wouldn't matter what you put in the vise, probably couldn't do much damage to a pair of old beat up wooden jaws. I know peening doesn't take much force, I just don't care to do any work on my woodworking vises. Now, if the OP has a machinist vise, or better yet a post vise, that would work dandy and most have v-notches in the aluminum jaws to secure round objects.
Stay warm.
Re: Insteresting...
paul womack
>I wonder if the same pratice could be used on absued drawknifes.
Unlikely. Scythe blades are soft enough to tolerate this cold forging, and indeed benefit from the work hardening involved.
On a decent (i.e. hardened tool steel) drawknife I would expect nothing but chips and fractures to result from the attempt.
BugBear
