Chisels and "ruler trick"
Bill Tindall, E.TN
>Among the rampage below on sharpening guides was a comment about ruler trick and chisels. I don't use this trick but I am getting encouraged to try it some day. I just have to get over the hours I have spend making backs flat, my least favorite woodworking chore.
I feel like I am about to ask a dumb question.......Why doesn't it work on chisels? I haven't tried it so this is an honest, if not dumb question. There was some angle calculation made which seemed like this back bevel would be very small, maybe insignificant? Or is any chisel back angle significant? Will such a small back bevel mess up chiseling? An answer by someone that has tried it would be preferred.
Re: Chisels and "ruler trick"
Paul Kierstead
>I have inadvertently used the ruler trick on a chisel (and been too lazy to grind it out). It does not tend to pare well, since lying the back flat puts the bevel higher then the wood.
Ian (in Sydney, Australia)
>Why doesn't the "ruler trick" work on chisels? (sorry I don't know how to italicise Bill's question)
a chisel needs a flat back as a reference face, especially when paring. The "ruler trick", if used, places the reference surface below the cutting edge and you then can't align the cutting edge with the (knifed) gauge line and have the chisel follow your line.
However, I'm not sure if a mortice chisel has to have the cutting edge coincident with the chisel's back, especially if you pare the last 1/64th from the end of your mortice, so the "ruler trick" might work. (with a mortice chisel, the sides are the primary control surfaces � preventing twisting)
Robin Corell in Atascadero Ca
>There are some carvers who prefer a double bevel edge on some tools. For carving it can give greater chip control. Paring is a completely different type of cut and you want your control to be the reference surface of the wood. When I bought a couple of used chisels they had been honed on a felt wheel and the back was slightly rounded, giving them the same geometry as the ruler trick, if less precise and a bit uglier. The only way I could use these chisels to accurately pare with was by holding them bevel down, which gives less control than a flat back with the bevel up.
I eventually got the backs of those chisels flat, but flat to me is not too obsessive. I don't hone the entire back of a chisel or worry about it being perfectly flat settling on getting about an inch of the back honed nicely with a nice polish fading about half that distance from the edge. I make money when I am using my tools not when I am sharpening them; the paradox is that they must be sharp to use them.
Robin
David Charlesworth
>Bill,
Ian has the explaination which I use.
best wishes,
David
paul womack
(Chuckle)
BugBear
