Shellac/Wax Finishing Question
Dave (Arlington, VA)
>Hi -
I am finishing a small box with a 1# cut of dewaxed garnet shellac (fresh - from flakes) by brush. I am on my 9th coat and will probably put on another one or two before turning to a final wax application. After every third (or so) coat I have been smoothing the shellac with 600 grit sandpaper and 0000 steel wool. I am trying to follow what I understand to be Jeff Jewitt's recommendation from homesteadfinishing.com.
So, here's my question: as I move from my last coat of shellac and before I apply the wax should I smooth the shellac with the sandpaper and/or steel wool, or just apply the wax over the last coat of shellac?
Some may want to encourage me to forgo the wax, however, I expect the inside of the box to get damp from time to time and wanted and additional layer of protection against moisture. In addition (and perhaps more importantly) I would like the final surface to have more of a satin finish than the gloss that is resulting from the shellac.
Thanks!
Dave
