ADVERTISE HERE - FREE TRIAL
Multiple face hand plane *LINK*
Re: Multiple face hand plane *LINK*
Bob Hackett
>I`ve seen a couple of them.All but one was either in a pattern makers box or from one.
MB
MikeW
>Hi Robert,
I have two of them, one handled and one unhandled. The handled one was made by a pattern maker, the other is made by Preston.
I bought the small one for smoothing the inside of coopered doors. I bought the handled one later for roughing the insides of the doors prior to the small one so I could leave it set fine.
They are patternmaker's planes. I cannot vouch for the eBay plane, but these both work exceptionally well. As with any profiled plane, one needs to pay attention when sharpening or honing to keep the profile matching the sole, but it is not as absolutely critical the irons/soles match like a molding plane--but keep them very close.
Take care, Mike
Core box plane
Robin Corell in Atascadero Ca
>There are many types of core box planes but most fall into two main categories. The first type would be those with curved soles. These can be fixed sole or interchangeable. The second type is one with a "v" shaped sole with a single narrow blade. This type can be the familiar Stanley or the automatic bailey and is used to make a perfect half circular cavity in a block of wood. Technically speaking this later type is the only true core box plane and the others are simply curved sole planes, but since they were mostly used to smooth out the rough surface left by the "V" soled planes they are always called core box planes.
The inter changeable sole core box plane I have is the only one like it that I have ever seen. I have seen several other metal bodied planes with either metal or wood soles. The most common metal bodied interchangeable sole plane on the west coast being the one that was made by Phelps mfg of Oakland CA and was made out of aluminum. I have seen these planes with one or two additional wood soles made by one of their owners. The Phelps as well as most of the others uses screws to attach the soles and require a screw driver to change soles. The unique thing about my plane is that the knob is used to tighten up the sole once it is slipped over the catches on the sole, therefore requiring no tools to change soles. My plane has a cast bronze sole with a frog from an early Stanley. Another unique thing about my plane is that it also has a flat wood sole in addition to the 4", 6", and 12" radii soles. This flat sole is the one I use most often and mostly with the 12" radius iron to make it a rather aggressive scrub plane. In use this plane is a nice user with good weight and a nice feel on the wood. The thin iron is prone to chatter on tough woods; otherwise I would use it more often.
I inherited this plane as part of tool kit I received as an apprentice. The patternmaker who owned my tools before me apprenticed during WWII. The older patternmakers who have seen this plane all agree that it is likely made by him.
Core box planes are obsolete in today�s patternshops having been largely replaced by Oscillating spindle sanders in the early part of the 20th century. The final nail in the proverbial coffin for core box planes was the advent of the high fidelity extreme low shrinkage two part castable polyurethanes. it is much faster to make a wood positive and pour a urethane mold of it to make a core box than it is to carve out an all wood core box.
Robin
Re: Core box plane- base
Re: Core box plane- frog
Lots of ingenuity among the mechanics
>of yesteryear.
It must have helped being able to get things cast easily. My dad got some drain gutter grilles cast when he couldn't find anything suitable, 50 years ago, and didn't have to drive more than three miles to drop off the pattern he'd made. Now, there are so few places casting iron I might have to drive for an hour or more to get a casting made.
Jim DeLaney, Austintown, Ohio
Re: Lots of ingenuity among the mechanics
>I'd guess the body started out as a #6 or #7, and was shortened to suit, then had the hook hardware for the soles attached. The cap iron and chip breaker look to be off a transitional, which had a different height adjuster slot than an iron plane, and would allow the blades to be set deeper to accommodate the thick wooden soles.
Jim D.
Robin Corell in Atascadero, CA
>Most patternmakers have access to a foundry and making a pattern for a tool like this is usually part of your apprinticeship. The base is cast bronze with the "L" shaped hook at the rear of the sole being part of the casting. A thin area around the perimiter of the sole is raised in comparison to the rest of the sole. This would have made it marginaly easier to machine but would also allow for the wood sole to be snuged up even if there is a bit of seasonal movement or slight warping.
You are correct about the frog and cap iron being from a transitional. I had originaly thought the plane was older because of this. I have never tried to fit a frog from a transitional to a standard base so I don't know if it would be possible to replicate one of these without the custom base casting. I supposde it would be a fun project though.
I forgot to include the diminsions before. The sole is 12" long and the blade is 2" wide
Robin
>While I understand the more historical context of the word 'mechanic', if you ever wish to insult a patternmaker that would be a good word to use. I am not so sensitive nor particular about what I am called as long as it's not late for dinner.
Not sure of any iron being poured within an hours drive for you. Cierecast in San Francisco used to do iron but they only used ceramic shell. I heard both Pacific Steel and McCauley closed a while back which would leave AB&I and General Foundry Service as the only ones pouring iron in the bay area. Brass and aluminum foundries are more plentiful with Castco, Production, and Kearny still in business along with a couple of smaller shops along with all the art foundries. There is an Iron foundry in Lodi and a couple in southern Ca but most of the iron has gone out of state or out of the country where it is less restrictive to burn coal.
Robin
"mechanic"
>I chose the term because I thought this community would understand it in its historical context - I agree that the modern connotation is rather less complimentary for the sophisticated trades, among which patternmaking is certainly included.
It's too bad - I worked briefly as an auto mechanic and was struck by the number of different sub-disciplines you had to master, at least intuitively, to be competent - electrical theory, machining practices, etc. The word should have more dignity than it does in modern culture.
Which leads me off topic to comment that I read a recent newspaper opinion piece in which the author referred to fishing, farming, car repair, and assembly line work as being for "learning-disabled men." I have yet to hear a reply to the furious letter to the editor I wrote.
