Powder coating vs. jappaning
Michael Brady
>This must have been suggested before, but wouldn't glossy black powder coat be a modern version of jappaning? What intrigues me about it that it can be done in the home shop or you can have it done by commercial shops. Anybody have thoughts or experience on this?
Re: Powder coating vs. jappaning
steve mackay
>Seen one powder coated and it looked nice. Probably tougher than paint but I've still got that spot in my heart for my japaning. Theres not another finnish that looks like that after you've done your own. Bottom-less.
I haven't, but...
Scott Burr in Ben Lomond CA
>Most of the LN planes are powder coated. Also the powder coated finishes are thinner (as in thickness) than japaning.
Re: Powder coating vs. jappaning *LINK*
Marv
>Hi Michael,
Fluidized Bed coating is more comparable to Japanning. The process however is too pricey for the ordinary person. Special equipment is required. I'm sure if you did some googling you would find where you can have it done commercially.
I'm including a website where you can learn about the process and it's advantages.
Marv
>Japaning is easily accomplished by mixing asphaltum in equal proportions to McCloskey's Marine Spar Varnish (gloss).
There is no substitute for the original.
Stephen
Re: No Substitute?
Marv
>Stephen,
You say there is no substitute for the original but you also say that
by mixing asphaltum in equal proportions to McCloskey's Marine Spar Varnish (gloss)..... isn't this a substitute for the original which is a substance from a certain tree in Japan?
I used to use the Fluidized Bed process back in 1960,s for coating any metal object that could withstand at least 350 degrees F. Epoxy powders were used and was and is available in many different colors. It is a great substitute for the original Japaning that we see on many old tools. The Fluidized Bed Process produces an even coating that is hard and tough but somewhat flexible. It resist abrasion and is a gloss finish. The best feature is how well it adheres to metal.
Lets not be telling the folks there is no substitute for the orignal. Do a little googling on Fluidized Bed Process and you will get lots of good information about it.
I really like the original Japaning, I only wish we could buy it in an airisol can.
Marv
Some confusion
>Japanning is a technique to copy the look of oriental lacquer work.
Oriental lacquer is from Rhus vernicifera, called japan wax or japan lacquer or urushi.
'A Treatise on Japaning and Varnishing', by Parker Stalker in 1688 probably introduced the term.
The old stuff was made with Asphaltum or it was also called Judean Pitch and Mineral Pitch.
Stephen
Mr. Stalker's . . .
steve mackay
>paper is well worth reading. You might go in search of japaning but if you don't learn WAY more than that something went wrong.
Here is a recipe from 1824
4 Japanning Articles Here on WC
Garrett in Victoria
>Go to Articles and Reviews and search on Japanning.
Cheers, Garrett
Editor
ThomD
>Don't know what product is being discussed, but in some cases the 400-450 degrees of typical PC could affect a tool's temper. I assume we are talking cast iron or something where that doesn't mater.
I use commercial powder coaters on some of the bike parts I make, and I have to say that even at that level there is a variability in durability that is well within the disappointment range. I would love to imagine that the Harbor freight kits etc... would be a solution to that problem. I haven't found a cheap enough stove yet to test that theory. I gather the family stove is a no no.
