Hide Glue in a bottle?
Marv
>Ok, I confess.....I have never used Hide Glue. You know, the stuff that's made from cow's hide? It's what jello is made of except the jello kind comes from pigs.
Stehpen has made me curious about the stuff. Went to TFWW and saw some hide glue in a bottle called Patrick Edward's Old Brown Glue.
I also did some Googling and read some instructions as to how to mix hide glue and how to use it. Seems that it needs to be used hot and temperature controlled and that there are different granule sizes that effects the set and cure time. And you have to make sure the viscosity is just right when it's applied.
After reading about all that is involved with preparing the stuff for use, it would be much faster and easier to buy Pat's Old Brown Glue in a bottle. It has a shelf life of about a year. What that probably means, is that it's good for about 6 months.
Those of you who are well practiced in using hide glues, other than differences in price, what is your recommendations regarding using the glue in a bottle versus mixing the granules? Keep in mind that I'm of an age that I need to be concerned about conserving my remaining hours.
Thanks,
Marv
