Plane Blade Help
Plane Blade Help
Plane Blade Help
Gene DiNardo
>Where can I purchase a new blade for an infill .
I need a 2 1/2" x 1/4" paralell Iron.
I have an Iron that will not take an edge.
I've tried shapton ceramics and DMT diamond.
This thing WILL NOT take an edge.
I believe it was improperly processed, annealing or tempering.
The steel is A2 it is not soft or overly hard, I think it is the structure of the steel itself. I know D2 doesn't like shaptons
so I tried diamond in case I got a D2 by mistake.
I will contact the person I got it from however, He is very slow processing orders and I want a replacement soon.The Iron must be 1/4"thick, as thats what I have opened the mouth to.(18"Cocobolo stuffed,bronze infill pannel plane)
If anyone knows where I might find a replacement, I would be most grateful.
Thanks, Gene
Re: Plane Blade Help
Hank Knight in SC
>Gene,
Call Lie-Nielsen and ask what they have in stock. They make replacement blades for some infills. I bought an A-2 for my Norris from them and it's a nice blade. I don't know what other sizes they make.
Hank
Bob Strawn
Re: Plane Blade Help *LINK*
Bob Strawn
>Hock is my reference for quality. I love my Hock Blades.
I have not gotten a blade yet from Jim Reed, but several woodworkers who I respect have seriously praised his work. He likes to make custom blades, and his prices are good.
Bob
Jim Reed
Right here... *LINK*
Scott Burr in Ben Lomond CA
>I have ordered several Hock infill blades from here (A2 steel). Ron himself you tell you to go here if it's not a custom thickness blade.
I don't believe LN sells infill blades. Their regular blades have the hole in the adjuster/ cap iron hole on the wrong end for a infill.
The Best Things
Gene DiNardo
>Thank you all for your help.
Actually Hock was my first thought.
This would be a custom order as I need 1/4" thick Iron and
I wasn't sure if he did custom blades.
I took the iron to the grinding wheel and re ground about 1/8"
thinking it may have been ground too hot and sure enough I got to good steel. whew! I guess my last resort should have been my first
attempt at a solution.
I'll post a pic this weekend.
Thanks again, Gene D
Good news
jim reed @ tallahassee
>That's good news. Sometimes the simple solution is the best. Good luck making shavings.
