Advanced Saw Filing and Restoration
Bob Smalser
A 6-dollar flea market beater? Yes, but this one is a Disston Acme 120, originally a cabinetmaker�s finish saw tapered and hardened to run without set, and one of Disston�s finest. So let�s see if it can be given another lifetime of use in a slightly different form.
Old saws filed so many times their tips resemble pencil-points usually aren�t worth the trouble, as when they get that thin and narrow they are too easily kinked, and this one�s no exception. Restoring this in its original 26-inch length isn�t a good option for it to survive another generation of use. So I�ll shorten it to panel saw length to make it useful again, but that�s not as straightforward as it seems if the saw is to please the eye and hand. Panel saws had smaller handles than their full-sized counterparts, and their blades were uniformly contoured to match their smaller proportions; they weren�t just stubby versions of full-sized saws.
I don�t have a small #120 handle, but I do have an extra Keenkutter panel saw handle and another complete matching saw to use as a pattern. These Keenkutter #88 skewback saws were made by Disston using #16 handles and probably P26 blades from the Harvey Peace factory they bought out, for which Disston offered custom etching in hardware store logos like EC Simmons�. Mr. Simmons knew his saws. These are not only excellent, taper ground saws, their profile pleases my eye. I scribe the new profile onto the #120 blade, and use the bevel gage to duplicate the tip angle. I�ll make the #120 a 22-inch saw based on the amount of blade remaining.
Saw steel grinds quickly and relatively cool using a coarse, 8� wheel, with the occasional water dip as the wheel gets close enough to burn what will be the final profile. Here I don�t just grind up to the scribed line, I take the line.
I fair the curves by drawfiling using 2d-cut and smoother 1st-cut single-cut files. This is done largely by feel. When I feel a bump I alter the file angle for a more aggressive cut, and finish using my finest single-cut file straight across. The files are chalked and frequently brushed both to keep them from clogging and to prevent stray filings from causing scratches during finishing. I rarely use chalk when jointing and sharpening however, as it often masks what I�m trying to see.
After fairing I ease the sharp edges slightly using the fine file in the drawfile mode.
I fit the new handle and drill the bolt holes using a cobalt bit. The easiest method is to mount the handle and carefully drill through it, indexing each fresh hole with a bolt to insure alignment is maintained. Clamp the saw down during drill extraction to prevent it riding up on the drill.
On the anvil using light and heavy hammers, I remove the saw�s tension, hammer out the kink and retension the entire blade as I�ve detailed in previous articles on permanently removing bends and lumps in saw blades. Saws straightened in a vise, by bending over the knee or even by hammering flat won�t remain straight for long without stretching the edge and back to restore the tension put into the blade when it was manufactured.
Continued�.
