Radiata pine for painted exterior use
>I need to buy some boards for use as exterior trim, and the local lumberyard offers redwood and cedar, both nominally 1" but actually 5/8", and radiata pine, nominally 1" but actually 3/4". The existing trim on our Victorian is 7/8" (insert brief nostalgic whine about the old days), which makes matching tricky.
Online research says that radiata pine (also known as Monterey pine, and a California native, it turns out) has low durability in exterior uses, unless treated. Does anyone have experience to confirm or refute that?
I don't know that I can afford to buy 2" stock and waste it down to 7/8", so I may be buying the 5/8" stuff and using 1/4" (true dimension) lath to shim it out. With enough filler and paint, it might pass...
