Re: Fret saw sources
Wiley Horne--So. Calif.
>Michael,
I like the combination that Chris S. talks about--jeweler's saw and scroll saw blades. You get the saw frame from a jewelry supply, and the scroll saw blades from a woodworking supply.
The stoutest and best jeweler's saw frame that I have come across is one recommended by David Barnett a coupla years ago (BTW, I've learned to take about all of David's recommendations). Contenti sells them. Here is the link--click on one of the first two 'Best' frames:
http://www.contenti.com/products/saws/sawframes.html
I like the 'fixed' one without the slide adjustment, because that thing will take big tension and not deflect.
I use Olson 'Regular Skip Tooth Scroll Saw Blades', and get them from here, although there are many suppliers:
http://www.sloanswoodshop.com/scroll_saw_blades.htm
On the blades, there are two key variables--the tpi and the thickness. I use No. 2 blades because the thickness (0.012") will just snake down a dozuki kerf, and I'm stuck with a 20tpi saw. But if you're using a
a western backsaw with a wider kerf, you could use a thicker blade and fewer tpi, and saw faster.
On the same note, if you're using a western backsaw, I think I'd take a look at those Olson coping saw blades that Joel is selling--he's very high on them, and Joel is very honest in his assessments. You might call him up and talk over the whole thing.
Wiley
