Attaching leather to wood?
Ernie Miller
>Shat is the best way to attach leather to wood? it will only be attached on one end and will need to move like a hinge but would like to get away from mechanical fasteners. is there a glue that will work?
Re: Attaching leather to wood?
contact cement...
Ted Owen, Pittsburgh
>Spray a light coat on both the wood and leather, let get tacky, spray another light coat, let get tacky--then press in place.
That's how I've attached leather to wooden vise jaws, and they've held up for years.
Best, Ted
Dean J in MN
>Good old hot hide glue -- works for the organ makers, should work for you.
-Dean
Marv
>Hi Ernie,
In order to determine if glue will do the job, we need to know what the hinge is being used for. Is there only one hinge? Or will there be two or more hinges supporting the same whatever? How heavy is the hinged object? Are we talking a few oz.,s or a few pounds, or ten pounds or more? What kind of wood? Is it smooth or rough? Will it have some kind of finish on it like shellac or varnish or poly? How long do you need it to work as a hinge, one day, a month, forever?
I remember as kid my Dad using leather from an old boot for hinges on the door of our outhouse. He used nails.
Marv,
PS...how bout tham hammers? Send me a picture or two. Any Osborne leather working hammers in the pile?
Don't know if this will work for your application
Scott Burr in Ben Lomond CA
>I asked same question a while back. I was making a strop. I used 3M-Scotch super 77 spray adhesive, and it works great. Thanks to Adam for recomending it.
Whtcha ya makin?
Do it all the time . . .
SteveM
>Carpenter's Glue ! Tite-Bond. Its on there GOOD ! Promise !
I think I used
Joanne in Point Pleasant, PA
>Perfect Glue # 1 (from Liquid Nails) when I glued suede to the wood on my guitar stand to protect instruments. Worked great.
2 part epoxy works well because....
A.J.
>... it will soak into both the leather and the wood and when cured the bond is just as much mechanical as it is chemical. The epoxy you use is a definite factor, I use the same 2 part medium cure time epoxy that I use for boat repair ( US Composites brand, less expensive than the competition and it works great!)because it has the added benefit of being Extremely water resistant (the term waterproof is applicable but do to legal concerns no manufacturer uses it anymore).
A.J.
