New Molding Plane
Paul in NJ
>I have been slowly building my collection of wooden planes but have not been able to find a decent ovolo at the flea markets or tool shows. My plan is to build the wooden planes I have trouble finding and this is my first molding plane. The plane is from a piece of beech I 're-discovered' from the back of my lumber rack and the blade is recycled from a trashed plane. The blade is bedded at 55 degrees. I think I spent 2-3 hours on the body and wedge but the shaping and tweaking of the blade took longer than that. I still need to refine the blade a little more as I can only adjust to take a thick shaving. In spite of the coarse shavings, it does a great job with the woods I normally would use. Pictured are sample cuts in curly maple, walnut, cherry, and pine. While it takes a coarse shaving at first, the last shaving before it hits the stop is thin. In any event it clears the shavings without choking, leaves no tear-out, and produces a better surface than my router table. Other than the blade grinding, it was built with hand tools. I do need to work on my aesthetic details like the chamfers.
Paul Dzioba
