saw making questions
Andrew Lunn
>Hello everyone. I posted here a little while back with some saw making questions, and you were all very helpful and generous with your knowledge. Perhaps not surprisingly, I have some more questions and am hoping you can help me once again. My questions here pertain to making a 24" panel saw.
First, do any of you tension your saw blades like used to be done by striking the blade with a hammer? I've tried to find information about this but have found very little. I did come across a piece by Bob Smalser about re-tensioning a blade--but am not sure this is the same process you would use to tension a blade in the first place that had never been under tension. It seemed to perhaps be something you'd do to rejuvenate a blade, and that the initial tensioning would be more elaborate.
Secondly, what do you do to correct a subtle wave or curve in the sheet of steel you buy to make your saw? Hammer it out? If this is the solution, can someone give me an idea of where to place hammer blows in relation to the bend? The material I'm using is 1095 spring steel, .035" thick.
Third, which way works best to make the holes in the blade for the handle screws? Punching them or drilling them?
Fourth, does the material you buy from a supplier come tempered or just hardened? If it needs tempered, how much time and temp. does it require in your oven?
And lastly, what is your preferred method for cutting out your blade from the sheet? I've seen the Norsewoodsmith site and see that he uses a circular saw. I thought that maybe using a hacksaw would be better because you could more easily control the heating of the blade and not overheat it. Does this sound right?
Thank you very much for any assistance.
Andrew
