200+ woodworking book reviews
Homebrew Plow Plane
Homebrew Plow Plane
Homebrew Plow Plane
Paul in NJ
>I have wanted a wooden plow for a while and when I found a set or irons cheaply, I decided to build my own. The wood is cherry with dogwood facing on the fence. I would have preferred beech or apple but both are difficult to obtain especially quarter sawn stock. The cherry worked easily except for some chipping at the arm and wedge mortices. John Whelan's books The Wooden Plane and Making Traditional Wooden Planes were a great help and inspiration. I used a combination of two of his planes as a starting point and I have a John Mosely sash filletster that was a help with the fence and arms. The hardware was made from brass and steel and while not difficult to fabricate it was time consuming. It was most helpful to have a drill press but it was hacksaw and file for the bulk of the work.
I probably would have done better with the mortices if I spent the time to make a float or two but I am happy with how the plane came together. The best part is that it works well and will be a welcome and well used addition to my kit.
Paul Dzioba
Re: Homebrew Plow Plane
Other Side
Paul in NJ
Michael Stadulis, in Gloucester County, NJ
>Hi fellow New Jerseyan,
Very, very nicely done, Paul, as usual. I too have had an "itch that won't go away", for a plow after I recently wasted out the wood on a deeply radiused cyma curve crown moulding on a table saw .......before finish-shaping the curves with my hollows and rounds. It was a lot of fun, and not too much time at all for the 8 feet that I needed. Believe it or not, I spent most of the time on the table saw. Best of all, I got the exact "old" crown profile that I wanted..... w/o the little cove at the bottom.
I remember driving to a millwork shop that had a Williams and Hussey molder, to get them to make it, and quickly decided against it when they quoted me 125 bucks just for cutting the knife blanks. It was a nice Sunday drive and luckily that pushed me over the edge to make it myself. I'm glad thatI did, and I bet that making it by hand was less time than what I invested to find someone else to make it for me. The table saw work would have been so much easier with a plow, so now I'm considering either and ECE or Ulmia. Have you seen their versions? Not nearly as pretty as yours, but the screwfence adjuster is what I'd like.
Hey, what makers mark did you use?
-Mike
-Mike
Jim in Burlington Ont.
Very Very nice
>Quite a pile of work to make one of those nice work.
Re: Very Very nice
Gary B in Central NY
>very nice....help a youngster out here, what exactly is a plow planes function?!?
That's a beaut!
Scott Burr in Ben Lomond, CA
>Very nicely done Paul! How's it work?
Looks great Paul...
John in NM
>Very, very nice work! I gotta make one of those one day soon.
John
My Mark
Paul in NJ
>Mike,
I haven't looked at the Ulmia or ECE since I wanted something more traditional but they make fine planes from what I have seen. Screw arms would have been easier if I had the tap and die but I rather like the wedge arms.
Paul Dzioba
function
Paul in NJ
>A plow makes a groove, that is it! It is adjustable for depth and distance from the edge of the board and comes with a set of cutters to do various widths. Think of a groove for the center panel in a frame and panel or the groove in tongue and grove.
Paul Dzioba
YIKES!
Adam Cherubini
>GADZOOKS PAUL!
How in the world did you make the depth stop? You mean to tell us that complicated little bit of machinery isn't salvage? You expect us to:
1) believe it
2) sit idly by while you slough it off as a bit of file and hack saw work?
How did you make the knob at the top? How did you make the plate that retains it?
You can't just drop the "I just made this plow plane" grenade on us. We want more- like photos, step by step instructions, matching dado planes!
It beautiful work Paul. I'm hoping to see you next weekend.
Adam
Please bring it...
Ted Owen, Pittsburgh
>to 5-Barns. I want to see it.
Your work always amazes, Paul.
Best, Ted
Congratulations
Vlad
>What an excellent job you did.
How long did it take you?
Vlad
Hardware
Paul in NJ
>Making the hardware was fun and not difficult in the scheme of building this plane. You use some of the same basic skills as in woodworking... marking, sawing straight and square, and filing. Just like woodworking you need sharp tools, need a stable bench, and a way to hold things securely. Working the metal is just a little slower and you have the advantage of not worrying about grain and chipping. My drill press was indispensable for drilling straight and square holes and I used the nose of a belt sander to shape the hollow in the depth adjuster knob.
In the picture you can see the combination of materials I used, some scavenged, some bought from the store. The depth adjuster knob came from the round stock and its base from a knurled nut. Both were through drilled and tapped 10-24 and screwed on to a piece of threaded rod with some high strength thread locker. The end was peined over for a little extra security. The mounting plate was made from the scavenged hinge and added to the threaded rod, followed by a washer and two hex nuts with thread locker. In traditional hardware the threaded rod would be a larger diameter and have a much coarser and faster pitch. I think the knob and retainer would be through drilled and pinned to capture them. I used thread locker since my threaded rod was thinner. I thought I would compromise the strength by pinning. The bottom plate of the foot was screwed onto the bar again with some thread locker, the heads peined and then filed flush.
Notice my first attempt at an adjuster knob in the right of the picture. As I was filing the hollow I broke through the threads. At the bottom left you see the remains of a brass pipe nipple. This is what remained after cutting the diamond nuts for the fence arms. The nipple was also used to make the end caps for the arms. I was dissapointed I could not fabricate the arch shaped end caps of originals. I never understood why they went to the trouble of putting on these end caps until it dawned on me it was for protection when the fence was adjusted by hammer or mallet.
I recently bought a reprint of a Preston catalog from Astragal Press. It was interesting to see all this hardware available in several grades for plow, filletster, and dado planes. It makes me wonder who was buying this stuff, small plane manufacturers or woodworkers like me.
Paul Dzioba
Re: Time
Paul in NJ
>I'm not sure how many hours, I was off last week and worked on it for a while most days. It makes me wonder how the professionals can make a living building planes at the quality that they do. The likes of Clark and Williams have nothing to fear from me!
Paul Dzioba
wow! Geat work
David Jeske
>Paul,
Wonderful job. Did you take any in-construction pictures? An article or lessons-learned discussion would be great for future reference. Thanks for sharing. So what's next, matching left and right adjustable panel raisers?
Dave
Very inspirational!
Norman (Ottawa, Ont.)
Wiley Horne
>Paul,
Really a wonderful piece of work, and inspirational.
I agree with you that the wedge-arm works great, and is a very fast setup.
Did you fashion a tongue on the front edge of the rear skate piece to match the irons? Or what? Seems like this would be a difficult part of the job.
Amazingly nice work!!
Wiley
Re: wow! Geat work
Paul in NJ
>Dave,
One of the lessons learned is that I need to make some floats before I do the next plane. My biggest pain was the mortices; I think they would have come out much cleaner using a proper float. I learned a lot looking at vintage planes at MWTCA, PATINA, and CRAFTS shows I have been to this year. As I always tell people when they are daunted by a project, just try it you just might surprise yourself.
I might try making some molding planes next. I hate setting up the router table unless I am making many feet of molding like when I trimmed my new house addition. While occasionally I find usable molding planes it is very difficult to find the combination of proper pitch, condition, and pattern furniture.
Paul Dzioba
Re: skate
Paul in NJ
>Wiley,
The leading edge of the skate was filed to a vee and mates and aligns with the matching groove plow irons are manufactured with. I marked the angle to cut the skate with a straight edge from the plane bed. After the skate was shaped it was pushed into position in its groove against the back of the wedged blade. I could now drill the screw pilot holes through the pre-drilled skate. It went smoothly but I was very careful not to get ahead of my self.
Paul Dzioba
Thank you--this should be an Article!
Wiley Horne
I agree, a beautiful job.
Pam Niedermayer - Austin, TX
But they save sanding time
>One of the folks in our finishing class last week at Marc Adams does exterior doors. He spends hours sanding shaper-made moldings by hand, usually breaking the crisp edges along the way.
I suggested he find some hollows and rounds and, following the shaper (or in your case router table) take a couple swipes to remove machine marks. Then, if things look OK, just apply his normal finish. Skip, or at least minimize, that sanding.
You don't necessarily need to find or make the perfect molding planes, Paul. They may end up too wide to push comfortably, anyway. Try hollows and rounds.
Best, Ted
Re: Thank you--this should be an Article!
Nathan Pettigrew
>Beautiful plane, great job there.
I've got Whelan's books and hope to make one some day soon. Would love to see an article and more photos of construction.
Thanks for sharing it with us!
Nathan
OUTSTANDING Job Paul
>Very nice Craftmanship AND Workmanship. Just can't put into words how nice I think this planes is.
Todd O.
