Bedrock 640 scrub plane *LINK*
Rob Brophy Niagara Falls Canada
>Thought it might be fun to build a #40 metal scrub plane in the Bedrock style. The body is MIG welded 1/8" cold rolled steel with extra pieces added on to the body under the knob and tote to give it the cast look. The lever cap was whittled out of a chunk of brass using hand files...no electrons were killed. Knob and tote are off an old #4 parts plane, cleaned up and slightly reshaped....Rob
More Pix
Re: Bedrock 640 scrub plane *LINK*
McKay from Utah
>Nice job. I see you stayed with the same blade retaining system that has a tendency to pop out when in use.
>That's funny...I have spent quite a few hours pushing a #40 and don't recall ever having that problem!
Todd O. Cronkhite Maine Native now in Jax Fl.
>Man, that is REAL COOL!! I want one PERIOD! How much will you charge me for one?
Todd O.
Who really likes Scrub planes.
Tom in Tipp
>I think that's a great looking tool, too. Nice job on something a little different--in an interesting sort of way!
Tom
Joe Rogers, Northern Virginia
>Just a beautifully constructed hand tool!! How many hours do you have in the job?
Some day that baby is gonna confuse the heck out of some bedrock collector:-)JR
Me too!!
Andy Lincoln,In Dearborn MI
Re: Three lunch hours...
>...two evenings, and one bottle of red wine. :-)
Thanks Joe...it was a fun project.
>Thanks Todd!
The first one is fun, the rest are work. ;-)
If I get around to building a batch of them I'll let you guys know first.
This style of plane construction is relatively easy...much simpler than compound dovetails. Cut the steel shapes, a small amount of grinding, MIG 'em together, sand,sand,sand, and a splash of Tremclad Black.
MIG welding is very simple...sign up for a class at a community college and make a whole mess of planes on their time and power bill....Rob
Learning MIG
>Rob,
It so happens that I not only work for a community college, but I work in the weld shop toolroom! As a result of this employment I can take my classes for FREE! :~) I've been trying to talk myself into taking the welding coarse, but couldn't quite do it, but you've pushed me over the edge now.
So, at what skill level would a newbie welder have to be at to be able to weld well enough to be able to do this?
Todd O.
Yo Andy
>The line starts RIGHT BEHIND ME! ;~)
How do I save this picture?
T.O.
Re: Learning MIG
>Hi Todd,
If you had a good teacher, and a basic but sound knowledge of metal working tools (die grinders, metal bandsaws, belt sanders, handfiles etc), I would guess that you'd be able to make a scrub plane after a few classes. It's very basic welding. Nothing fancy...a few methods to follow to reduce warping, but no 'secrets'.
Most of my time in this project was spent filing that damned brass lever cap.
Do yourself a favour and get one of those (good quality) auto dimming helmets...you won't regret it....Rob
That's one cool scrub plane!
Hank Knight in SC
Re: Yo Andy
Andy Lincoln,in Dearborn,MI
>Todd,
Hold the pointer of your mouse over the picture,right click and scroll/select the option to Save Picture As.....
Andy
Scrub Pattern
>Rob,
What did you use for the pattern?
-How long,wide and thick is the sole?
-How tall are the sides?
-How long are the cheek flats?
-How did you make that ring under the knob?
How about a few disassembled shots?
Also, how about a few "action" shots eh? I enjoy to see shaving from homemade tools.
Red Wine huh? Hmmmmmmmmmmmmmmmmm Wayne drinks wine as well, must be something to it. What would you recommend for a nice fruity wine?
Todd O.
Todd O.
Who'll never sleep tonight
Re: Yo Andy
>Got it Andy, Thanks! Saved it in My Pictures. Didn't get the text tho, can that be saved with the pic as well?
T.O.
Re: Scrub Pattern
>Hey Todd,
I used the Stanley 40 (hit the link in the first message) in the first photo as a rough pattern. I took the plane apart, traced the body profile on some card and drew the shoulders to suit my eye. The plane was built as a gift for a friend who likes diminutive tools so I reduced a few dimensions to give the plane a finer look.
I'll trace the plane and scan it rather than try to give measurements...this way you can print a copy and use it as a pattern. I'll email the scan to you tomorrow.
The raised ring on the knob is just a steel washer with a bevelled edge. The tote boss is a scrap of 1/8" cold rolled steel cut to match the base of the tote. The 'nib' for holding the front of the tote is a short length of 3/16" wire set into a hole and tacked in place.
And I'm normally partial to Alexander Keith's India Pale Ale...the red wine was just a poor substitute. :-)
Re: Yo Andy
>Todd,
If you have Microsoft Word....start,all programs,microsoft word you will be able to save the whole shebang.
Open the message(text and pic you'd like to save) hold the left button on the mouse and scroll thru until the text and pic are highlighted,press crtl + c ,then open a word document and press crtl + v
Dan Clermont in Burnaby
>Very nice Rob!!! You should start marketing them ;
That is a very pretty plane
Cheers
Dan Clermont
That ROCKS!
Scott Burr in Ben Lomond, CA
>"The lever cap was whittled out of a chunk of brass using hand files"
You da' man! That's some sweet work! Congrats on a job well done.
Make's me wanna make one...
Ahhhh! Brilliant!
So....
>To make a 604 1/2, more wine or lunch hours? Inquiry minds...
Blade retaining system
Jim Reed @ Tallahassee
>I was surprised to hear your comment about the blade retaining system *popping out during use*. It has never happened to me, but I can guess at some of the causes. #1 cause is dull blade. Nothing makes a plane harder to push than a dull blade. #2 cause is a cut that is too aggressive. Planes, even scrubs, should go swish. It is easier to make two or three passes at *swish* than one big grinding *scrape*. #3 cause could be knots. The solution here is DON'T PLANE KNOTS. Cut them out with a beater chisel. Knots will damage both your blade and your plane. Good luck woodworking.
Re: Blade retaining system
Alice Frampton, UK
>It's happened to me - the blade was sharp, the cut was ridiculously light, no knots. IIRC there was some others on the Old Tools list who also had the same trouble. I fixed it by carefully filing the notches on the lever cap just a smidgeon deeper. Mind you that was a #40 1/2; maybe the #40 doesn't suffer from the same trouble?
Cheers, Alf
Wow!
John in NM
>Nice work Rob,
I didn't look at that the first couple times around, but man I'm glad I finally did. Very professional job. Next on the list is an infill scrub plane! ;)
John
