Stanley 45 knob
Stanley 45 knob
Stanley 45 knob
Rob in Ontario
>I have a #45 that is missing the round knob that threads onto the fence. Can someone please give me the dimensions ( dia. and ht. ) so I can make a new one.
Thanks: Rob.
Re: Stanley 45 knob
Re: Stanley 45 knob
Dave Thompson - Champaign IL
>My type 14 (1922) #45 knob has a diameter of 1 9/16", and a height of 1 5/8".
enjoy,
Dave
Re: Stanley 45 knob
Also remember
Jim Reed @ Tallahassee
>most of the knobs are not perfect spheres. They have a little turned ring on the bottom where they screw into the fence. This acts like a standoff and makes the knob sit proud of the fence so that it is easier to grip. Good luck with your project. I have made many of them with much success.
Re: Stanley 45 knob
Re: Stanley 45 knob for threaded wood
>My 45 has the super-coarse threads on the post, intended to mate to a threaded wood knob. Any hints on how to make a knob for this style? I've considered greasing the post, filling the hole with a filled epoxy, and mooshing it on; or tapping a hole to take a through-screw (like a bench plane knob).
Re: Stanley 45 knob
Rob in Ontario
>Hi Bill.
My 45 has the same threads on the fence. One idea from someone here at WC was to wrap a small piece of glue soaked cloth around the threads then jam the knob on. This is what I am going to try. This way you are not permanently changing the plane from its original condition, and the knob should unscrew if you need to remove it for finishing or re-shaping.
Rob
Re: Stanley 45 knob
What I did
>I drilled a hole that was slightly smaller than the thread diameter so that the knob had to be screwed on with hand pressure. Drill some holes in scrap to find the right fit. After the knob was finished I filled the hole 1/2 full of glue and screwed it on the post upside down so that the glue would not run. After drying everything seemed solid, but I always thought it could be unscrewed with a little effort.
Re: Stanley 45 knob
Link *LINK*
David
>Stan Faullin sells them. You can still make your own, but there is some info on the various knob post diameters. No affilation.
Tool Trip
