Is it a rabbet or a fillister?
George Makowski
>Well Folks, some of you may have read the thread below about cutting rabbets. One of the spin off questions in that thread was what is a rabbet and what is a fillister?
I dug out the books I have on hand last night, the Ten Speed Press series of reprints of ca. 1900 woodworking manuals and searched the web with Google to see if I could find some answer. Here is the result of my investigation. It may not hold for other historical periods.
A rabbett is a step cut in the edge of a board, long grain or end grain. A fillister is a rabbet cut on the out side of sash window framing elements to hold the glass and glazing materials (Webster's dictionary 1913). More commonly, a fillister is a rabbet plane equipped with a fence, depth stop, and spur. The fillister may have a fence that simply allows the width of the rabbet to be regulated when cutting on the close side of the work, or it may have a long-armed fence that allows it to also cut a rabbet on the far side of the work. The latter type is ometimes also called a sash fillester apparently since sash window elements need rabbets cut on both the close and far sides of the work, rabbets which in this case are also fillesters.
Thanks to all for a push to look this up and share what I found.
George in AL
