Made a couple of devils :)
Skip in Falls Church
>I've been working on a couple of chairmakers devils and I'm just about done. I've gotten the first coat of BLO on them and I'm making the blades now. I just thought I'd put up a couple of pictures now because I can't stand it. :) The bodies are made out of jatoba and apple with brass wear strips. I used brass 1/4 - 20 threaded inserts and brass machine screws to hold the front pieces on. The diameters are 7/8" and 5/8" Making them was fairly straight forward and relatively easy.
Re: Made a couple of devils :)
Another view
Dave Anderson Chester, NH
>Very nice work Skip. I particularly like the fact that you decorated the little devils with a Celtic knot design. They look really great.
>I'll take two please - well maybe one for now ;).
Sweeeeeeet!
Scott in Douglassville, PA
>Let's hear how they work after you get the blades in 'em!
Jim in Burlington Ont.
Sweet
>Hope they work as good as they look.
>Thanks Dave,
Celtic knotwork is one of my recurrent themes (when I do carve soemthing) - particularly apt in this case as the Celts (at least some of them) held that apple was a "magic" wood. And I'm hoping that it performs a little magic. I think I went a little too far though, my wife thinks they are so pretty that a chair simply *must* come next. I was thinking a little farther out in time than she is.
Skip
Re: Sweeeeeeet!
>Thanks Scott,
I finished the blades a little while ago. Another coat of BLO on the wood and I might get to try them out a little before I go to work tomorrow night.
Skip
Re: Sweet
>Me too! I'm actually afraid the bodies are a little deep and the shavings might clog the throat. I think if I make more (and I probably will) that I'll eliminate the carving and try to get the body a bit lower. Although that might change if they work okay because it would be nice to have a matched set.
Skip
>Hi JL,
They're easy enough to do - if you decide to make one, do two instead. :)
Skip
Re: Sweeeeeeet!
L. Hanson
>"I finished the blades a little while ago. Another coat of BLO on the wood and I might get to try them out a little before I go to work tomorrow night"
I'll be looking for the shavings here! Outstanding work, Skip!
Leif
www.norsewoodsmith.com
paul womack
>If they work well, you might consider putting the plans (or just a description) up on the web (e.g. as an article here) so the next guy who wants to make a chairmaker's devil has an easier time...
On the web, it just needs each one of us to give a little, and we all get a lot.
BugBear
Re: Sweeeeeeet!
>Thanks Lief,
I'll try them out this evening or tomorrow before I go to work and gt some pictures.
Skip
>Hi Bugbear,
I actually took pictures along the way with that thought in mind. There seemed to be so much interest in devils when I asked for tips that it seemed that it might be a good thing to do. The process was actually pretty simple - excepting the little brass wear plates which probably aren't necessary. I actually followed Lee Valley's instructions from their spokeshave kit to dome degree.
My instincts tell me that I should have made them a bit lower - eliminating the carving with a thicker front piece to allow a larger throat and a lower center of gravity - but I'll try these out first. Since I'd only seen them in pictures and never used or handled any it was hard to judge how to make them.
Skip
>If you rework the handles on the next ones, be sure to keep these. They are really good looking, and will be a family treasure some day. I like your carvings.
For starters, I should mention that I have not used one of these, so the ergonomic advise that follows is all theoretical. I am assuming that you pull on the devil, while the chair spindle is held in a shaving horse, and that the blade takes a scraping cut, right? If so, I agree that you should get much better control if you drop the handles. Where they are now, it looks like you will get some torque, because the center line of the handle is well above the center of the scraper blade. I expect the torque will make them tiring to hold, because the handles will want to twist in your grip, and you will have to squeeze harder to keep the blade perpendicular to the tenon. It also appears that the surfaces where you will be applying the pressure with your hands are quite small, because the handles are narrow. I think the handles would be more comfortable if widened in that direction. You might also want to consider giving the handles a little bend in the other axis, slightly curving them away from your center, so that you will keep your wrists straight when pulling. The grip that I imagine using puts you hands closer together than your elbows. If any of this makes any sense at all, but is still not clear enough, let me know, and I can make a couple of drawings. I guess you could say I'm "playing the devil's advocate" :^)
David Galloway
>Skip, as a new chairmaker, I am intrigued by all the tools. I would be very appreciative if you would share the pictures/plans at some point. You do beautiful work
David
OK Skip, what's next...
Scott Burr in Ben Lomond CA
>A travasher? The devil's look great. A nice addition to your spokeshaves. Looking forward to see how they preform.
How did you attach the brass wear plates?
Great idea!
>You've got to do a travisher next!
Scott, still needing to finish his travisher
Shavings! I've got shavings!
>I tried both of them out this morning on a piece of ash shovel handle I'm going to turn into a hammer handle. First, it was really nice that they worked - and worked well in my unexperienced, biased opinion. :) Throat clogging was not an issue - the one time that some shavings did build up in the 7/8" one I was able to just blow them out. So far I'm really happy with them.
Skip
>Thanks David,
I took pictures along the way with the thought in mind that if they worked it might make a good article for Wood Central. So, when I get a little time, I'll put it together and submit it.
Skip
Re: OK Skip, what's next...
>Thanks Scott,
A travisher would be fun, I think. Guess I'll have to buy a blade for that. :(
I attached the wear plates with itty bitty brass screws I stole from some small hinges I bought a while back. The wear plates were really a pain to attach and *probably* not necessary - but I think they add a little class. I clamped the proto wear plates centered in the opening then drilled a hole in the center, drilled the opening out a bit with a countersink and screwed it down. Then I took the clamps off and drilled holes to either side and screwed them down. I used three screws for each wear plate. When I finished the devils I sanded any protruding screw heads down even with the wear plates.
I don't know how well this picture will show it - but you should be able to see the screws.
Skip
Re: Great idea!
>Hi Scott,
I know there have been some travisher blade sources posted - but do you have any good sources for blades?
Skip
>Thanks for the compliments William.
Well, I've got - what? Twenty or thirty minutes of use on you? :) So, considering that immense difference in experience this is my provisional judgement: The lower center of gravity is definitely better - but doesn't seem that critical. Both were surprisingly comfortable to use. I'd definitely make the handles a little longer on the next one, I have big hands and longer handles would be better for me. I thought about curving the handles before I started - but decided to go with a slight gull wing because I'd never used one before. I'm going to use these a little more to see how the ergonomics work out. Your ideas make sense - but I'm going to put a little more time in on these and see how they feel. I'm defintely thinking about making at least one more - something a little over 1" - I think.
BTW, I've been holding the future hammer handle in my vise since I haven't gotten around to making a shaving pony yet. (I've got the plans socked away somewhere - guess I'll have to dig them out and make one.) A shaving horse is simply out of the question - no room in my tiny shop or slightly larger "back yard".
Skip
