I'm no chicken! Top 'o the workbench to ya'!
David Hammond, in Powder Springs GA
>I've been planning on gluing up my bench top piece by piece for months now - almost a year. But I got a really wild hair Thursday afternoon: I started dry fitting my bench top together - I tried my 1 1/2 cylinders in the holes through the top that are for the twin screw, and I tried the clamps to see how they would pull the whole pile of lumber together. Everything seemed to be just right: the holes were lining up, the boards were pulling together, the sawhorses I was using to support the top were spot on level, and level to one another. So, I did everything I could possibly think of to get ready:
I waxed my 1 1/2 cylinders, the insides of all the holes and mortises in the top, set up my glue with a pan, and a 2" paint roller. I also threaded the ends of these cylinders and made four temporary nuts so I could fit the cylinders in the holes for alignment, and use them as clamps as well to pull the top together.
So like a maniac I started spreading glue - I hustled, running around back and forth like crazy for an hour, spreading a gallon of Titebond 2 on both sides of 20 2x6x12's... I threaded the cylinders through the holes, and started piling on the clamps - whew! Talk about being nervous... Later Thursday night I pulled the cylinders so they wouldn't get stuck, and this morning I walked out to check on the glue up job: success! Everything looks almost perfect:
I've started planing the top, and I've still a ways to go, but it's really pretty flat right now, I mostly need to get rid of some tear out. The only flaw I can find is a bit of a parallelogram (sp?) in my top. Even with two tight dowels for alignment, I'm almost a 1/4 of an inch out of square - not what I want, but I don't think it's really going to change anything, the dowels still fit.
So anyway, that's my crazy story, and though I might have avoided that bit of out of squareness, I'm glad I just went for the whole sack o' potatoes at once! I think I'm going to take a little time to set up my twin screw, planing stop, and maybe some holes for the holdfasts so I can build the base with my new bench top, but we'll see.
Thanks for taking a look!
David
The picture is right before I started spreading glue - the clamps are ready to go, but putting them right under the boards was a little less than brilliant - by the time I was spreading glue on the last board, the first ones were dripping a bit of glue all over the clamps... Now I know for next time!
Re: I'm no chicken! Top 'o the workbench to ya'!
>Above is a shot of the top all clamped together, gluing up into one massive block of wood. It takes a bit of grunting just to lift one end of this top off one sawhorse - this top has got to be 300 lbs plus, and needless to say, it's rock solid! I wondered if the weight would give me trouble with sag, but it seems spot on right now.
This picture is what the top looks like now, pretty flat, but it needs some more attention to finish getting flat and to get rid of some tearout.
Terrific benchtop, David ...
>... it looks like you could just leave it on the tressle legs, plane away, and it would still be rock solid!
>Glad to see it together. Talk about heavy!
WOW
Jim Reed@Tallahassee
>That's a nice looking top taking shape. I hate a bench that moves & from the size of yours it looks like you will not be dealing with that problem. Thanks for the pictures.
Steve Kubien
12ft?
Steve Kubien
>Now that's massive! Very nice and thanks for sharing.
Steve Kubien
John Clifford
>Dave I recently glued up the top of my bench also all in one shot. It took less than 15 minutes to spread the glue and get the clamps on. It definately raised my pulse. Heck of a feeling to do all that work to get to that point and know that you could mess it up entirely in a few moments. Who needs sky diving or bungee jumping for an adreniline rush, a complicated glue up will accomplish the same thing. Great job Dave. Feels good, doesn't it? :)
>David,
glad to see that you took the plunge---after a year of aganizing--and that everythng turned out fine. Must of been all that pre-planning eh? ;~) I'd have to say that after gluing up all those (how many)2x6's and you came out only a 1/4" out of square than you done real good. Really can't see why your stressed over a bit of tearout tho. Heck after a short time of use,you'd never notice it anyhow. DAMHIKT. What you got in mind for a finish? I didn't finish mine, and now wish I had as it's all dirty and grimey now and looks a' fright. It's really not that important of an issue tho in the long run. A nice finsih would make it easier to get off bits of dried glue tho.
Now than, you may of said, but do you have in mind for:
-vises, if any
-base/legs
-dog holes, if any
-gonna have a sliding board jack?
-add'l accesories?
Man, that's a heck of a benchtop I must say. At 12 ft, what special purpose do your have in mind, if any, for such a long bench? Make spars/masts for sailboats perhaps?
Todd O.
Re: Terrific benchtop, David ...
>Thanks Derek, and actually that's exactly what I'm planning on doing - I'd like to get the bench functional on the sawhorses, to aide building the leg set - it doesn't even try to move just sitting on those sawhorses, so I should be able to plane away, and use my twin screw, just sitting on those horses.
David
>Thanks JL, and yeah it really is heavy - I'm guessing it's over 300 lbs... Hey, I've still got your books, and if you need them back you're welcome to come anytime to pick them up, they've been great to look at and read - if you need me to get them to you, let me know.
David
Re: WOW
>No movement here Jim! Not even just sitting on the sawhorses; I'm really pleased with the stability so far, and it should only get better when I get it all finished.
David
Re: Thanks Steve!
>Exactly John! That really was a huge rush scrambling around trying to get all those boards together... No bungee jumping for me!
Thanks,
David
Re: Answers:
>Thanks Todd O - I'm really glad I took the plunge; that tearout isn't really stressing me, but I know I can do better so I'm going to go over it a bit more. And it was 20 2x6's, 12' long - I've never even attempted a glue-up close to that huge!
As far as a finish - I'm probably just going to wipe it down a couple of times with Watco, and no wax. I'm with you and Adam, I'm not looking to make my bench into a piece of furniture, I want to make furniture with my bench!
Let's see:
Vise: all those holes and the two dowels I was talking about are for a twin screw vise; wooden screws and something like 24 or 28" between the screws - I can't seem to remember how big I decided on...
Base and legs: more SYP - 3 2x8's laminated together for the legs, and 2 2x6's laminated together for the stretchers.
Dog holes: no dog holes, because the bench is void of a tail vise - but I will have holes for holdfasts.
Sliding board jack: no jack, but I will have holes in the flush legs where I can toss a 2x4 between the legs, held in place with holdfasts, for edge joining.
Add'l accessories: bench hooks for cross cutting and a planing stop are all I've got planned for now, but I'm sure more will come as the needs arise.
12' is a heck of top, but I built this thing long for several reasons: One, I've been blessed with a huge shop, some 32' long. So, I had the room first of all. But I wanted to incorperate all the operations into a bench, without having to add and remove accesories. So with a 12' top I can have a big wooden twin screw, and still have room to join an 8' board with the battons on the legs, and any length board with a free-standing bench slave. But really, my bench needs are somewhat yet to be determined - I've never built anything really using hand tools; I've not built much of anything, hand tools, power tools or not, so I've got a lot to learn with this bench, and I'm looking forward to figuring out what I can do with this new tool.
Thanks,
David
Dean J in MN
>It's Alive!
Looking great!
-Dean
