Carving chisel?
Ernie Miller
>Is the sweep of a chisel basicaly consistant between makers? Say a 1/4" #9 gouge it it going to be pretty much the same arc with most any manufacturer?
Carving chisel?
Ernie Miller
Re: Carving chisel?
Joel
>That would be way too easy.
Typcially the English manufacters use London pattern sweeps which are about one step higher than the Europeans. that is a #7 English is about a #8 European.
But of course that's too easy also.
Over time the swage blocks and dies used to make the gouges wear and you are not gureneeteed an exact match between any two makers - close - but no cigar.
Re: Carving chisel?
Ernie Miller
>If a pattern calls for # 7 bent gouge is there enough differance between makers to matter?
Re: Carving chisel?
Joel
>probably not as long as you are consistent. in other words if your #7 straight is Germany and your #7 bent is English in certain cases it may be annoying - but I personally am not that compulsive and wouldn't care.
In general as you get more experienced in carving and more used to how each tool YOU have performs all the differences go away and your brain and hands will automatically compensate for differences.
Re: Carving chisel?
Tony - Memphis
>Yeah, my carving is not quite to the level that it matters!
Tony
