Speaking of Router planes...
Christopher Fitch @ Memphis
>I need some help.
I have a Record 071 router plane. It's complete except for the screw and washer that holds the fence in place. Obviously, it's difficult to use without it for certain tasks.
I have been trying to find someone to supply me with a replacement but I have had no luck.
Can anyone tell me what the size, length, and thread count is for that screw?
TIA
Re: Speaking of Router planes...
Ernie Miller
>I bet it's a common metric. But I don't know Jack
Frank D. in Montreal
>Hi Christopher,
I'm no hardware expert but I tried to measure:
-the threaded part is 5/8" long, bang on
-the head is 5/32" high, 3/8" in diameter
-the threads appear to be 20 TPI (seems pretty well bang on too, but I don't know if there's a metric thread that is close to this measurement)
-the shank including the threads is 3/16" thick (diameter)
-the washer is 1/2" OD
hope this helps
Frank
>Thanks Frank, I'll see if I can find a match.
paul womack
3/16" OD x 20 TPI is no standard thread I can find.
UK 3/16 BSW is either 24 or 32 TPI (standard or fine)
and OD 1/4" whitworth is 20 TPI.
BugBear
>Hi Paul and Chrstopher,
Thanks for the haeds up, I knew I'd screw this up!
The 20 TPI seems exact, but I'll let you guys figure it out. I gave you 1/2" on the ruler for your measuring pleasure:
>Now here's the OD for the shank & threads. It reads 0.212 to 0.213" on my calipers. You can also read the metric measurements if you wish, my calipers give both:
Re: DUMB!
paul womack
It's the most standard non-standard plane thread. I should have guessed sooner.
http://www.geocities.com/plybench/tour.html#stanley_threads
BugBear (feeling foolish)
