Weird hinges
Weird hinges
Weird hinges
Jeremy Osner
>Hi all, I've been away from the list for a little while -- I picked up a whole bunch of old hinges at the church rummage sale this morning, most of them are just regular hinges with two pieces and a pin (and they match the hinges in our house, nice to have on hand) -- but one pair is different. They are only two pieces, so the pin is built into the upper half and you would take the door off just by lifting it up; I have seen hinges like this before -- but these ones mate along a spiral track, so as you open the door it lifts up about half and inch, and as you close the door it sinks back down. Is this just an automatic closing mechanism? I am thinking the door would pull itself closed. Anyone see these before?
Re: Weird hinges
Re: Weird hinges
>I think these may be the kind that make the door lift so it clears carpeting as it opens.
Re: Weird hinges
Re: Weird hinges
Jeremy Osner
>Oh yeah, that would make sense. Seems like you would need to shave off a bit of clearance on the top of the door though to keep it from bumping into the frame as it opened. at least at the inside corner of the top.
Re: Weird hinges
Re: Weird hinges
>Don't know, my knowledge on this is all theoretical.
Nice to see your name again, Jeremy. How's the family?
Re: Weird hinges
Re: Weird hinges
Alister
>they are used on shutter doors ...the kind that the cowboys walk through to the saloon in Westerns.
Re: Weird hinges
Re: Weird hinges
ernie miller
>I think them are differant in the fact that they set in a V so they swing back to closed automaticly. Jeramy are these entry door hinges or smaller for some peice of furnature?
Re: Weird hinges
Re: Weird hinges
paul womack
"Rising hinges"
I thought these were fairly standard. If well lubrucated, they will swing a door closed, although not hard enough to operate a latch.
AFAIK their main purpose is to clear carpets, so I wouldn't expect to see them in (e.g.) Italy, where fitted carpets are not common.
I have several doors in my house so fitted.
Here's a common bulk supplier in the UK
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=19256&ts=14189
BugBear
Re: Weird hinges
Re: Weird hinges
Jeremy Osner
>Hi Ernie, they are big enough for an entry door.
