Lie-Nielsen Handplane Choice Revisitted...
Erik S. Friis, back in Dodge
>Well after re-reading several of the very informative posts in my thread below and speaking with Lie-Nielsen as well, I decided to ammend my original choice of planes.
The compatibility of the frog & blade of the 4-1/2 with the 5-1/2 and 7 (any others) kept nagging at me (or was that my wife ;-) and LN also felt the 4-1/2 was a better selection for me.
I also noted the post regarding the better feel of the iron 4 or even the 3 for lighter work such as trimming dt's.
So I decided to go with a std. 4-1/2 AND a bronze 3. At 5.5 lb (#4-1/2) it has more heft than the bronze 4 and I can take advantage of the compatibility with the other planes (I believe the #4 was only compatible with the #5). Also for lighter work I'll have the #3 with the bronze body giving it a little more heft.
I am still going with the low angle adj-mouth block plane, I realize that some say they gather dust, but as a beginner I like the idea of having a smaller plane that can be used with one hand. If Cosman uses one it can't be that bad a tool and as I said earlier, it's a much lower investment than its bigger brothers.
So I just wanted to provide an update -- I struggled with these choices, esp. not being able to get my hands on them first, but I feel a little more comfortable with my choices now even though I've laid out some more money. I appreciate all of the guidance provided in the thread below. Slippery slope indeed.
Regards, Erik
Re: Lie-Nielsen Handplane Choice Revisitted...
Steve Kubien
Steve Kubien
>Well done Erik. I doubt you could have come to a 'wrong' or 'bad' decision based on the advice you received. And you're right, if Cosman is using it, you are probably on the right track. Remember, hand tool users/junkies can be an opinionated group. What works for one may not work for all.
Enjoy the slope.
Steve Kubien
Clay C in Miami
>And, if you find that block plane gathering dust, I'll be VERY surprised ...
Clay
Todd Stock
>...so dusty I've worn out two blades on the LA alone, not to mention the three other blocks that get used on a daily basis. Maybe if we wrote the copy as G-W might have done...
"Special narrow low angle adjustable mouth plane ergonomically engineered for either single or two handed use. By bringing the grip down near the cutting edge, this plane acts as an extension to your hands. The available chamfering guides and latest Euro-design 'ball' type handle only add to the utility of this essential tool."
good choices...
John Jesseph
