200+ woodworking book reviews
Rehabbed smoother
Rehabbed smoother
Rehabbed smoother
Skip in Falls Church
>I got this smoother from someone I know at work. He said that it had been in the family for generations - but he had no use for it and wanted to see it go to a good home. It was in pretty rough shape when I got it, it was dirty, neglected, had (has) a crack down one side and had a wide open mouth. On the good side it has a Marples Hibernia laminated blade with a Mathieson & Sons cap iron that had been well maintained although the iron had been as well worn as the plane.
When I disassembled the plane I found it had a cardboard shim in the throat apparently in an attempt to close the throat up a bit. When I removed the shim I found that the iron was only supported on the sides. I could actually see daylight between the iron and most of the throat with the iron wedged in. The crack, however, did not go all the way through the side of the plane.
To rehab the plane I flattened the throat, cut out a patch to close up the mouth - started laying in the patch - then realized the plane had been worn out of square. So I leveled the bottom of the plane and had to recut a patch as the original patch would have left the mouth open too wide. But I finally got the patch in then leveled the patch to the sole and then sanded the entire sole flat on my granite reference plate. I also flattened the back of the wedge the same way. I lightly scraped the plane and wedge to remove the years of build up and put a couple of coats of BLO/turp on the them. I also put a several coats of wax on the sole.
Whoever maintained the iron had done a fairly good job on it. It had a 22.5 degree primary bevel with a 25 degree secondary bevel. I was actually able to sharpen the blade in a few minutes. Well, except that the blade had been sharpened to match the sole - so it wasn't square. After I squared it up I redid the secondary bevel down to 220 grit (SS) then put about a 27.5 degree tertiary bevel on with 1500 and 2500 grit. When I was done I tried it out on a piece of black walnut and it cut quite acceptably. :)
Skip
Re: Rehabbed smoother
Another view
Sole
Patch
Re: Nice Job
Barry Va Beach
>Skip, it looks great - glad you put it back to use Barry
Thanks Barry!
Thanks for the pics
Bob Hackett
>Nice job of putting an old tool back to work.It says alot that folks feel that you`ll give these orphans a good home.
Just a suggestion,if you bring the plane and an easily planed piece of wood over to show the donor and then let him make some shavings of his own you may have a convert.
One fellow who gave me a plane has his (long,thin)shavings displayed in an old jar we turned a wood cap for.He says it marks the moment he turned the corner to REAL woodworking.
Mainely,Bob
Re: Thanks for the pics
>You're welcome Bob. I thought about doing just as you suggested - but we work in an office and I'm still trying to figure out how to secure a piece of wood to a computer desk. (Without harming the desk.) I did bring it in and show it to him after I had the mouth patch in and the junk scraped off it. He was impressed.
I keep trying to lure people at work in - letting them see my saw handles as I'm making them, bringing in planes - you know the routine, trying to hook people. There are a lot of engineers around so I like to emphasize the science behind the tools too. I have a few people interested but they seem to feel hand tools are a bit too esoteric. It seems that the engineers around are more attracted to gismosity and to them that means power tools. But maybe I'll hook one of them one of these days.
Skip
Bob Hackett
>As my brother(an avid fly fisher)says"It`s not so much about the fish as it is the fishing".
I know all about those engineers.I see them all the time at the turning club.
Keep up the good work.
Mainely,Bob
