Skew blade templates for the LV Honing Guide II *LINK*
>Hi all
This is an expansion on the previous post a few days ago, when I offered a set up for the Stanley #140 block plane. Shortly after this, I was asked for a similar set up for a #79 side rabbet plane.
It occurred to me that building templates is quite straight forward, and I’d like to offer a guideline here. The LN #140 will have slightly different template dimensions to the Stanley version, plus the LN comes in both Left and Right versions.
I have built a #140 template (below) as an example of the process. The steps involved are:
1) measure the mouth angle of the skew (see picture below).
2) The other relevant measurement is the distance between the start and stop on the blade registration jig. The setting for a 25 degree bevel is #2 (yellow) on the Honing Guide and Green 17 degrees (or Red 35 degrees) on the Registration Jig.
3) Transfer the dimensions to a durable material (I have used a cutting board), and cut this out.
4) Place the template on the Registration Jig and set up blade.
5) Reverse it for the other hand (my Stanley is used here for illustration).
It is important to do your own measurements as sometimes these will differ between planes. For example, although I have above used 70 degrees for the Stanley #140, mine is in fact 69 degrees (which is why I had to regrind the brand new LN blade I got for it. Damn!).
Hope this helps.
The measurements for the #79 will be posted separately.
Previous post
