Got a good workout but couldn't flatten panel
Alan Tolchinsky
>Hi again, I post yesterday about having problems flattening a small table top about 14"x 25". I wound up getting that pretty flat before sanding. Then I tried to flatten one side of a 9" x 25" maple board just to see if I could do it.
Well I couldn't. I used my #7 plane with very sharp blade at 25 degree grind. The board was cupped all along the center lengthwise and had some twist in it according to my winding sticks.
I first planed the edges to reduce some of the cup. Then I started planing diagonally from one end of the board to the other in a cross hatch pattern. I kept using my straight edge and winding sticks to check on flattness and twist in the board.
In the end all I got was a mess. :( There were low spots on the ends and it was way out of flat after working hard for an hour. At least I got some good exercise. (See a silver lining after all)
So I went back over with it with the winding sticks to get one side flat enough to go through the planer. After planing, the board was still slightly out of flat I'm sure due to the fact I hadn't properly flattened one side before planing. So I'm stumped for today but I haven't given up. I still want to learn how to do this but I'll give my arms a day to rest. Alan (sore in Md.)
