A55 Smoothing Plane
chisel caddy
chisel caddy
chisel caddy
Clay C in Miami
>I just Friday finished a design class at CofR, and for the last 4-5 days, our assignment was to make something that 'honors or elevates' an ordinary object or action.
So, I made a caddy, to hold a half-dozen or so of the chisels, rasps, whatever I'm using at any one time on a project. The idea is that this way, these don't get lost under piles of shavings, scraps, offcuts, etc., on the bench, don't bang edges, and are held at a comfortable angle. The handle could stand to be a little taller to clear, but I mounted it toward the back, so the weight of the contents makes it hang at an angle, such that the tool hanldles clear the caddy handle. The Japanese-theme was just a whim - one of the first week's 2.5-hour 'blitz' projects included half the class making 'wabi-sabi' (roughly, Japanese-rustic) war toys. I was in the other half, which made 'modernistic' war toys, and this was my opportunity to play around in the Japanese aesthetic I'd missed out on in the first week.
I'll post two pics - this one shows it 'upright, in carrying position, the next shows it in 'bench access' position. I didn't have time to put a finish on it, and the brass-pin hinges are still protruding, because I'm not sure that I won't want to rework the handle entirely, and this way I can remove them easily.
Since I may still do some refining now that the class and the time pressure is over, any thoughts or suggestions are welcome ...
Clay
Re: chisel caddy
ooops - pic 1
Clay C in Miami
Re: chisel caddy
pic 2
Clay C in Miami
Re: chisel caddy
Questions!
bill tindall
>First, that is a great idea and nicely executed.
But how in the world did you get it assembled? I think I can see the joints which all seem to be butt joints. Which leaves me to wonder how you were able to get it in the clamps while keeping the multitude of parts aligned, and aligned perfect it would seem?
Re: chisel caddy
Re: Questions!
Clay C in Miami
>The short answer - it's largely a 'bandsaw box.'
Starting from the block of walnut, I bandsawed off a 1/4" slab from each of the front, back, and bottom (in that order). Then I sawed/milled/chiseled out all the slots, and glued the slabs back on (all at once - see glue-up pic below). Then, I bandsawed the profile off, and finally attached the handle.
Mine was by no means the best piece in the class - I'll post a pic of what was by consensus the 'winner,' a fly-swatter case/coffin, which the maker called 'Tribute To The Death Of Flies.' And, I've got pics of all the class's pieces if anyone's interested - there was a holder for Scotch tape, a nightlight, a cookbook hoder, a box to hold one CD, etc., etc.
Also, I got an email question - the disk in my caddy handle is end-grain from a palm tree.
Clay
