Brillant Hand Plane
>Good Morning Friends,
Can anybody tell me anything about this plane, which came from my friend Kurt's estate? It is slightly more than 8 inches long by 2 inches wide. The iron has a stamping which looks like "Kunz". Behind the frog on the upper bed casting is the number "600". The tote displays a very worn decal which says "Marke" on the top, and "Zeit 1910" on the bottom. The center portion of the decal is too worn for any discernable image. The upper portion of the iron is cut out on both sides to accept little brass wheels which bear on the iron. These brass wheels sit on twin threaded shafts which are screwed into the frog. The purpose of the wheels is to position the iron through the mouth of the plane. The word "Brillant" is cast into the cap iron. I suspect its of German origin. I haven't used it yet. Its is real good shape.
George
George
