Lee Valley vise question
John Clifford
>I'm currently building a bench and I've bought the Lee Valley large front vise #70G08.02. The vise includes two support collets that get counter bored into the face of the rear jaw that the guide rods run through. My bench top when finished will be about 3 or 3 1/4 inches thick and will not have an apron/skirt. The plans call for a "half rear jaw" that attaches to the underside of the bench and flush with the front of the bench. The support collets go into this "half rear jaw. My question is this: are the support collets necessary? It seems like a lot of extra work to add the half rear jaw and counter bore the holes for the support collets. I'd like to attach the vise without the additional half rear jaw because the front of the bench at approx. 3 inches of surface seems like plenty of clamping surface. On Chris Schwarz's $175 bench I believe he used this vise and the picture shows he didn't use the half rear jaw. Has anyone installed this vise and if so did you use/need the support collets? Thanks in advance for any help with this.
Very excited about finally having a proper woodworking bench. John.
Re: Lee Valley vise question
Christopher Schwarz
>John,
I eventually added a half jaw to mine. And it really helped keep the clamping jaw vertical and biting down hard on the work, especially at the top edge.
My guess is that no matter how thick your benchtop is that the half jaw would help. Though I could be dead dead wrong.
Good luck!
Chris
Christopher Fitch @ Memphis
>I used a half-rear jaw with the collets...
My bench top is a little over 2 3/4" thick (almost 2 7/8").
I'll post a series of pictures starting here.
Excuse the mess...I'm painting a bookcase then I'm putting a couple of clear coats on it...
Image 1
>from the top...
Image 2
>from the side
Image 3
>from underneath
Thanks Chris and Chris
John Clifford
>Thanks for the advice (hmm, adVISE) I'll go with the half rear jaw. I wasn't trying to be lazy or cut any corners, I guess I'm a little eager to get this bench up and runing sooner rather that later, first one and all. I'll post pictures when I'm done and probably some pictures of the building process as I've been taking some for posterity sake. Oh yeah, I'll have to post pictures of my current bench, the one I inherited when I bought my house, plywood top with drywall screw heads sticking up and a machinist vise. To clamp anything to it is a monumental effort.
Can't wait to join the ranks who have a REAL woodworker's bench.
Thanks, John Clifford
