Blade thickness question
Roberto Perez F
>The Veritas Bevel-Up Smoother and Low-Angle Jack Plane can accommodate a 25°, 38° or 50° blades that are 3/16" (0.187") thick however, the Low-Angle Smooth Plane can only use a 25° or a 38° bevel blades that are 1/8" thick, how come this two planes have a thinner 1/16” blade?
Re: Blade thickness question
Tim of Livermore
>I'll go out on a limb and say they have different blades because they're different planes.... :- )
I'd likely think the wider iron on the Jack/Heavy Smoother is probably why Veritas went with a thicker iron......perhaps they found chatter could be a problem with the wider iron and higher bevel angles on really dense woods.
Or perhaps it is because Rob, despite selling a jig to help hand sharpening straight cutting edges, knows that a thicker iron is helpful for freehand sharpening?
Tim
Rob Lee
>Hi Tim/Roberto....
Blade thickness is like chicken soup....it can't hurt!
1/8" blades are plenty thick for LA planes. The 3/16" material was virtually the same cost - so we selected it for the bevel up series.
Cheers -
Rob
Re: errr. are you sure?
paul womack
With the up-to-the-edge bedding, I can believe that.
Given machining and heat treatment costs I can believe that too.
No ya' didn't; unless your website is wrong:
http://www.leevalley.com/wood/page.aspx?c=2&p=45864&cat=1,41182,48944
"Veritas® Low-Angle Smooth Plane"
The 2" wide A2 tool steel blade (1/8" thick) is hardened to Rc60-62...
I think this is what the thread is about.
BugBear
Alice Frampton, UK
>I think the "Bevel-Up series" means the Jack (#62.5), the Bevel-Up Smoother (#164.5H) and the not-yet-released jointer (#762.3F or something, I don't doubt), which all take the same blade. Whereas the Low Angle Smoother (#164) doesn't count; presumably because it's not one of the "series" and doesn't get invited to the right parties...
Cheers, Alf
Rob Lee
>Hi Paul -
Alf's correct...
We make a distinction between "Low-angle", and "Bevel-up"...maybe it splitting hairs - but at least we aren't calling 'em all block planes.... :)
Cheers -
Rob
