200+ woodworking book reviews
My bench again
My bench again
My bench again
David Hammond, in Powder Springs GA
>I'm slowly making progress on the never-ending bench project, and I've got another question:
I was planning on gluing up three 2 by 6's for the legs of my bench - they're going to be flush with the top. How would you attach the legs to the top? I was planning on a huge motise and tenon - basically letting the middle 2 by be my tenon, and the other two 2 by's that make up the legs, be the shoulders. My top is going to be 20 2 by 6's glued up face to face, 12 feet long - so obviously the top is massive and will weigh a ton - what say you about joing this together?
Thanks guys,
David
Re: My bench again
Jack Guzman from Maine
Re: My bench again
>The only thing holding my bench top to the frame is a 1" dowel on each end.The dowels are fitted into the center of each upper stretcher and fit in a hole under the top.No glue,just gavity.The top never moves,but if I ever need to move the bench I can lift the top off.---Jack
Re: My bench again
Re: My bench again
Ed Mulligan, Cape Cod
>Same as Jack, I have a couple 1" dowels on the base trestles which fit into corresponding holes in the underside of the top.
If you go with the leg tenons, I'd recommend they be very short (3/4" max) for ease of fitting and use only two along the top length to avoid expansion/contraction issues.
Re: My bench again
Right on, David
Christopher Schwarz
>David,
What you describe is exactly the way I built my recent bench, and I recommend it highly. My leg tenons were more than 2" long, built up from laminations and drawbored into the top with 3/8" oak pegs.
And as to wood movement.... I actually think you want it the top to move and distort the base. With a bench built like this, the strength of the whole thing is derived from the top, not the stretchers (like in a dining table). So when the top shrinks, the base distorts into an A-frame like structure (which is more stable).
This distortion was described in Scott Landis's chapter on Robert Tarule's Roubo-style bench. I've noted the same distortion on my bench.
Chris
Re: My bench again
Laminated tenons
Christopher Schwarz
>David,
Here's a photo of the tenons I created on the legs and stretchers by laminating.
Re: My bench again
Mortise in the top
Christopher Schwarz
>David,
And here you can see the mortise laid out on the underside of my top. This will put the leg flush to the front edge, an important detail (thanks Adam!)
Chris
Re: My bench again
Re: Right on, David
Kurt Loup, Baton Rouge
>Bench looks great. Appears you used pine for the base. What did you use for the top?
Kurt
Re: My bench again
Re: Right on, David
Christopher Schwarz
>Kurt,
The top and the base are Southern yellow pine. The pegs for drawboring are white oa. It weighs about 350 pounds.
Chris
Re: My bench again
Nice picture.....
Tony - Memphis
>Sitting here in my office (cube actually)....that's a cruel thing to show me! You ought to put that in the magazine! Nice bench too.
Tony - who's daydreaming sawdust but supposed to be designing a new package scanning system!
Re: My bench again
Re: My bench again
>Second (third or whatever) the 1" dowel. I also beveled the top of the dowels a little bit to help them "find" the bench top easier.
Re: My bench again
Re: My bench again
Dean J in MN
>David --
Good to hear the update! I'd take the advice Chris gave, and be sure to note the detail of the legs being flush with the front of the bench.
12' long... I wish my shop was big enough to fit a 12 footer in it! :)
-Dean
Re: My bench again
Re: Right on, David
William Claspy in Cleveland
>Beautiful bench, Chris, and even nicer picture. I wish I had a window like that above my bench! Any chance you've got a high res version of that picture? It'd make a great wallpaper for my computer screen...
Also, I notice you cropped the picture to leave out the right hand side. Does this bench have an end vise?
Wm
Re: My bench again
Re: Mortise in the top
>Fantastic Christopher! I appreciate the post very much - all of the answers as a matter of fact. Hey, could I ask a favor - how about a few more pics of your bench, in action - it really looks great! My bench is going to be very similair, and like you, much of it was drawn from Rob Tarule's bench, and thoughts from Adam. Bench fever is setting in deep, that's for sure! I can't wait to start gluing everything up...
Thanks again.
David
Re: My bench again
Re: My bench again
>Yeah Dean, I'm very grateful for such a shop - the shop is 32' feet long, a real dream that I thought would be years and years down the road. But, I've got more than enough room for this 12' monster; we'll see if I can pull it off!
Hey, as an aside, and another question: I'm considering adding an oak wear strip (I've got access to some free, good quality oak, that's dry) to the font of my bench - on the top, legs, and stretchers, as everything will be flush - what do you think? With that wear strip, I could then make my vise jaw and crochet to match out of the oak... Hmm, there is so much to think about building a bench!
Thanks.
David
Re: My bench again
Re: My bench again
Dean J in MN
>David --
First, I'm heading over when I need to stick a 10' molding...
I forget what the benchtop/legs are made of? Regardless I'm not sure the wear strip will do all that much. The front/legs don't see any real wear per say, and the top really doesn't either. It isn't as if you are rubbing the wood over the top. It just sits there. Sure there is wear, but that is what gives the bench its story and character. Keep it simple. When you wear out the bench, build another. :-)
-Dean
Re: My bench again
Crochet for edge work
Christopher Schwarz
>David,
Using the crochet and holdfasts for edging.
Re: My bench again
Crochet for dovetailing
Christopher Schwarz
>This is my favorite. The crochet kicks butt for dovetailing. Totally solid. When i do a case side I sub a clamp for the holdfast.
Re: My bench again
Battens are the Secret
Christopher Schwarz
>Thanks to Dean, Rob Tarule and Adam, I've learned the secret of the batten.
They can do anything.
Re: My bench again
Wide Panels
Christopher Schwarz
>Easy.
Re: My bench again
No tail vise
Christopher Schwarz
>The bench has no tail vise. I haven't found a need for it.
Chris
Re: My bench again
Re: Battens are the Secret
Dan Moening
>Those are wonderful looking holdfasts.
They seem to be made from a single piece of iron bent over.
Can you share a source?
And thanks for all the action shots. It's always a joy to see how other utilize their benches.
Dan.
Re: My bench again
Re: Crochet for edge work
Jeremy Osner
>Does the leg vise come off? It looks like in this picture you are working where the leg vise is in the other picture...
Re: My bench again
Re: Crochet for dovetailing *LINK*
Rob in Peoria
>Christopher, that's fantastic. It never occured to me that you could use a crochet (how's that word pronounced, anyway? Like the yarn thing my mother does to make sweaters?) to dovetail a board like that.
Seeing your bench in action I'm thinking more and more that I might save the money I was going to spend on tail vice and invest in holdfasts, instead.
Hand Tool Knowledge Base
Re: My bench again
>And is that a Phil Koontz holdfast lurking on the batten? Very nice indeed.
Bill
Re: My bench again
Christopher Schwarz
>Yup, the leg vise unscrews right off. I take it off pretty regularly, too.
Chris
