new box
new box
new box
Matt- Los Angeles
>Just finished this little "watch caddy" for a friend of mine. He took me on a great golf vacation so the least I could do was give him a little trinket, or a box to hold his trinkets...
Matt - Los Angeles
Re: new box
oops...no pic
Matt- Los Angeles
>not sure what I did wrong...the pic was there in the preview
Re: new box
Re: new box trying again
Matt- Los Angeles
Re: new box
Don't post from preview
Dan Donaldson
>If you post from the preview, the picture gets lost. If you preview, hit the back button to get back to the original input before you hit post. This is an ongoing problem. It was prevalent in Firefox before, but seems to be affecting other browsers now that we are on a new server. What browser are you using? (just asking because if it is not Firefox, then we need to try to figure out what is going on.)
Re: new box
Re: new box
Alan Bierbaum
>Don't post from preview - many people are losing the pictures by doing that.
Re: new box
okay...3rd attempt
Matt- Los Angeles
>I'm using Safari as my browser if that helps...
Re: new box
another
Matt- Los Angeles
Re: new box
1 more
Matt- Los Angeles
Re: new box
Nice box
Dan Donaldson
>I like the inlay in the top especially, nice detail.
Re: new box
thanks dan and...
Matt- Los Angeles
>thanks for pic posting tip. Worked like a charm..
Matt - Los Angeles
Re: new box
Jack Guzman from Maine
Re: new box
>Matt,nice box.Looks like a great exersize in dovetail joinery. How are the handles attached? What are the box dimensions?--Jack
Re: new box
Steve Kubien
Re: new box
Steve Kubien
>Very nice work Matt. What are the overall dimensions? Also, how did you go about the sliding dovetails? Electron eater?
Thanks for sharing,
Steve Kubien
Ajax, Ontario
Re: new box
Re: new box
Hank Knight from SC
>Very nice, and the joinery is very well done. Your friend should be pleased.
Re: new box
Re: new box
Wendell @ Murphy, TX
>Nice box. Could you tell some more about the inlay? How did you do it? Is it done with thin veneers or thicker pieces? I think inlays and carving are details that take a good piece and make it an excellent piece. Good job.
Wendell
Re: new box
thanks and some stats
Matt- Los Angeles
>The box is about 11" w x 5" deep. About 5" tall.
The dovetails in the case front are half lapped and set in there is a web frame supporting the drawers. The pulls are notched into the top of the drawers...
All of the joinery was done by hand.
I didn't post this pic before out of sheer embarrassment for the holes left in the drawer sides. They didn't bother me in the overall look of the box when I made but the picture really made me cringe.
Matt - Los Angeles
Re: new box
Thanks Wendell
Matt- Los Angeles
>I made the inlay by cutting the diamond piece in maple. I milled the piece to about 3/16" thick. I then attached the Rosewood band. I just lined up the sticks and marked the angle with a little chisel tap. Sawed to the line and glued the pieces on. This was my first attempt at a bordered inlay, easier than I thought. Once it was dry, I planed it flat on the bottom, stuck it to my box with double stick tape and scribed lines around it.
It was a little dicey because on two sides my scribe lines were quite faint. I had to tilt the box this way and that to see them. That was a big mistake because it made chopping to the lines pretty scary. I guess I just didn't press hard enough initially.
When it was all cleaned out I glued it in and planed it flush...The overall depth of the recess was 1/8". That's about it
Thanks for looking
Matt - Los Angeles
Re: new box
Pesky wabbets
Jim Reed @ Tallahassee
>Sorry for the bad wordplay 8-)
I have the same problem with bottom rabbits on drawer fronts. What I do is cut a small niblet of wood and glue it in the hole after the drawer is finished. With a little chisel work and a little sanding, the wood matches and the unsightly rabbet end disappears. That is one pretty box and I am sure your friend will be pleased.
Re: new box
Next time
Sandor in Boyds, MD
>That is one very nice keepsake box. Impressive work.
About those rabbets for the drawer bottoms...
You can conceal them on your next project by judicious placement of the drawer side tails. This has worked well for me. Perhaps in your drawer you could have had two tails, then the lower one could have hidden the rabbet.
my 2¢
Sandor
Re: new box
Hmmm, Shades of...
Scott Burr in Ben Lomond CA
>Sideways? Nice golf vacation...After all that wine I can see why you had problems posting a pic. ;^)
Very nice looking box. I have to agree on the rabbits. Hiding them as Sandor explaned works very well. Again a fine job.
Re: new box
Re: Hmmm, Shades of...
Matt- Los Angeles
>yes
sandor, Jim and scott--
that is usually the approach I take...For some reason though, they looked kind of uniform and "cool" when I assembled it and I thought "well, I'll just leave em"...I won't do that again I don't think...Thanks for looking and your 6 cents....
Matt
