Face Vise Capacity Issue Solved
Hank Knight in SC
>What do you do when you need to camp a 20" panel and you have only 18" between the screws of your Veritas twin screw vise? Here's my solution. I imbedded 4 stainless steel machinist's T slot nuts in the dog hole strip when I built my Bench (see following pics). Two SS treaded studs with oversized washers, two aluminum speed handles and a piece of 8/4 hard maple give me up to 29" of rock-solid "face vise" clamping capacity. Sometimes thing work out the way you plan. This works like a charm
Re: Face Vise Capacity Issue Solved
Pic Didn't Load - Try Again
Hank Knight in SC
What Gives?
Hank Knight in SC
>The message preview shows the picture just fine , but the pic doesn't upload with the message. The pic is 36KB so it should load . An suggestions?
One More Try
Hank Knight in SC
>Here's the original Pic - I hope.
Here's The T Slot Nut
Hank Knight in SC
>These nuts are very heavy duty.
Here's The Dog Hole Strip With Nuts
Hank Knight in SC
Here Are The Studs And The Speed Handles
Hank Knight in SC
Don't post from preview
Dan Donaldson
>Many times, the picture will get lost if you post from the preview. Back up to the original entry and post from there and the picture should show up fine.
Re: Don't post from preview
Hank Knight in SC
>Thanks Dan. I noticed that when I backed up from priview, the picture address no longer appeared in the graphic upload space. I had to preview the text and then add the picture address after I previewed. It's never done that before. Strange.
Dan Donaldson
>I think that part of it might be small differences with the new server. It appears to parse some things differently. For some reason, Firefox seems to be more susceptible to this also.
Re: Dan, a suggestion
>Would might it help if the explanation on the preview screen included a warning about disappearing pictures, recalcitrant canine browsers and suggested procedural remedies? I know this is a long shot, even though this is a recurring problem, because we all know how averse some of us are to reading instructions (Only, when all else fails...) :^)
Steve Kubien
Very nice Hank...
Steve Kubien
>That's similar to what I want to do on my next bench. My thinking had been to bore a few holes through the bench (front to back) for a pipe clamp. I would only use the part with the screw on it. This gives me another idea (the list of which keeps on growing). I do not want to attach a permanent vise to my next bench. It will always be in the way for something.
Thanks for sharing,
Steve Kubien
Ajax, Ontario
>I use a system that works in a similar manner for holding complicated things down on the top of my bench. You can find explanations and diagrams in the WC articles. You might find the homemade wooden alternatives for the speed handles particularly interesting. I have not yet adapted it to holding simpler things to the front of the bench. Your system of making and mounting the nuts is very robust. I took the easy way out, and just installed threaded inserts into the top of the bench surface. If you have a hardwood top, I'm sure that would be more than sufficient, in either the top or the front. I've been using mine for about seven years in a top made mostly of particle board, and have not yet had one pull out. I am, however, still expecting a failure any day now, which I would have to fix with some epoxy.
The only reason I have not yet installed the threaded inserts in the face of the bench, other than being terminally lazy, is that I have pipe clamps, lots of them. One side of the panel gets clamped in the face vise, and the other gets clamped with a pipe clamp laid across the top of the bench. If I needed clearance across the top and end of the work, and the pipe clamp would get in my way, I could put the clamp under the bench top, where it would hold the panel just as well, but would require a little more sinisterity (you right-handers might be more comfortable with "dexterity") to get the clamp tightened.
We would have to ask the Boss on this one;-)
Dan Donaldson
>I am not sure where the instructions are located on the server, and don't know if Ellis would want to change them.
Hank Knight in SC
>William, when your threaded inserts finally pull out, you could drill through you bench top and install t-nuts from the bottom side. That way, tightening the threaded rod to clamp something to the bench top would exert a compression force on the bench top rather than against the threaded insert. Just a thought.
