Heat gun for "unfreezing" a screw?
Denis Chénard, Orléans, Ont.
>I had three frozen screws on my Millers Falls 85 that I'm trying to restore. I have fed WD-40 and penetrating oil on the screws whenever I walked by the plane in the last week. Tonight I tried to get these screws off, no luck by hand (actually, I didn't dare try harder than I did even if I could, because I've broken many screws and bolts in the past when I really torqued them).
So I pulled out my impact driver, went at it slowly, and bingo, the two lever cap screws came off without trouble.
Next I tried the screw that holds that little scoring spur (what's the proper name for it?), and this one still refuses to budge. Actually I partly stripped the screw head trying to take it out. Repeated applications of penetrating oil did nothing to help.
Out of ideas, I thought of applying some heat in the screw neighborhood to try to loosen it. From my old days when I helped my father work under rusty cars, he used the acetylene torch to heat the recalcitrant bolt cherry red while I had the impact wrench ready to loosen the bolt as soon as he moved the torch away. Worked every time...
Now, I would never do that on a handplane. I'm just wondering if a heat gun can get hot enough to be of any help in getting the screw loose. I assume the screw is size #6, if that changes anything.
If anyone has suggestions, I'm all ears...
TIA,
DC
