200+ woodworking book reviews
Rust Removal
Rust Removal
Rust Removal
bill tindall
>While at Winterthur I was able to meet with the person responsible for metal conservation. I asked him if electrolysis was used to conserve rusty museum objects.
"Not any more" was the answer. While Winterthur had two large electrolysis tanks, they are no longer used. The current "fashion" is to leave the pieces looking old and "rusty", while at the same time preventing further deterioration. Now rusty pieces are gently abraded with burshes and/or "sand blasting" with soft media. The loose rust is removed and the removal process stopped at various stages depending on how "rusty" a final look is desired.
However, objects recovered from the sea are subjected to electrolysis because it removes chloride which is essential for preservation.
Re: Rust Removal
Re: Rust Removal
>Bill,
What is the reasoning behind the change of mindset? I can understand to a point, but not completely. Interesting tho.
Todd O.
Re: Rust Removal
two reasons for change
bill tindall
>I was told....
1. The mechanical removal process can be stopped at any depth to result in what ever appearance of "old" is desired. Recall Todd's many comments about the look he (and presumably customers)prefers .
2. The latest conservation philosophy is to do nothing that will irreversably alter the object. electrolysis results in a permanent alteration of the metal surface. Apparently mechanical removal of loose rust is not considered alteration. ie. fashion change.
