Veritas - Innovation in Tools
DISSTON SAW
DISSTON SAW
DISSTON SAW
Walter McClain
>I bought a Disston Saw from one of my former co-workers yesterday. It has the Disston and sons medallion and most of the writing on the blade. How can you tell what number it should be? D-whatever?
Re: DISSTON SAW
Re: Disston Saw *LINK*
>Start at the Disstonian Institute.
Re: DISSTON SAW
Thanks
Walter McClain
>It is a D-8 made before 1918.
Re: DISSTON SAW
Re: Thanks
Joe Rogers, Northern Virginia
>I bet you really like the feel of the handle on that D8. That is a nice era for user saws.JR
Re: DISSTON SAW
Re: Thanks
Walter McClain
>Sure feel better than the VA I usually use. Will find out how it cuts tomorrow although it appears unused, it did have some scratches with rust but I cleaned that off.
Re: DISSTON SAW
Re: Thanks
>Walt, if it cuts worse than the VA don't despair. Most saws cut better after a resharpening than they did new anyway.JR
Re: DISSTON SAW
Re:How in the world
Mike McDaniel
>did you surmise that it was a D8, from that discription?
Mike McDaniel
Re: DISSTON SAW
Re:How in the world
Walter McClain
>From the handle shape, the medallion and the fact that it has an 8 stamped on the upper part of the blade and the etching!!:)
Re: DISSTON SAW
Re:How in the world
Todd Hughes
>If it is stamped with an 8 that is the number of teeth it had per inch and has nothing to do with it being a D8 saw.Should be a skew back saw and the etch should say D8 and handle should be Apple and not carved though some others like the no.76 had very simular handles.While the medalion can help to date the saw it of course has nothing to do with determing what number it is other then the D115's which are nickle plated....Todd
Re: DISSTON SAW
Re:How in the world
Mike McDaniel
>Tod makes some very valid points, but lets not forget the feature that made the D8 famous, the inlet handle. Sometimes referred to as the cover top.
My first post on this subject(how in the world)was made, before I realized that the saws owner identified it as a D8. (I really should be more careful when reading these messages.) Looking back, I should have made the assumption, that Walter checked out the Link, made the ID, and then re-posted. I'll try to be more prudent.
Mike McDaniel
