Record Chisel Question
Kerry in FortSask
>Hi again,
I mostly lurk around here but ask a question once in a while. I recently picked up a used set of carving chisels. The box is clearly an original chisel box from Record, however there are no markings whatsoever on the chisels. Did Record produce chisels with no markings? The box does seem sized right for this set of chisels. The chisels themselves are in good shape other than some rust which I'll remove. I got them to use, not to collect but still I'd like to know if they are indeed Record brand. They can't be terribly old - the box has some particle type board in it. Anyway, if anyone happens to know if Record marked all of their chisels, I'd appreciate knowing, thanks.
Kerry
