Winch Handle Pocket
Winch Handle Pocket
Winch Handle Pocket
Bob Smalser, Seabeck, WA
>An easy extension of the Bird�s Mouth Spar technique:
Continued�
Re: Winch Handle Pocket
Part II
>Items for boats are finished different from items of furniture�besides the exterior finishes�.this is 50-50 Daly�s Teak Oil and BLO wet-sanded into the mahogany followed by 6 coats of Epiphanes spar varnish�there can be no crisp edges because crisp edges won�t hold varnish very long in sun, sea and sand.
Dave (Arlington, VA)
>Thanks, again, for your posts, Bob. I really enjoy seeing the process of building something with wood. I appreciate your sharing these.
A question: how did you make the bird's mouth cut on the pocket? Hand tools? Router? Table saw?
Regards -
Dave
Table Saw.
>Quicker to make two passes than to set up the router table for a small job.
Feather boards weren't needed on stock this short.
Makes sense
>Thanks, Bob. That makes sense.
Do you know: does this mean there weren't any bird's mouth spars made back in the days before power tools? Just curious if this is a new technique that has developed because of new tools.
Regards -
Dave
Post-War, I believe
>I think you're right.....the oldies I've seen were coopered like a barrel when they were coopered.
Thanks!
>I always enjoy (and more importantly, learn something from) your posts.
Regards -
Dave
