Belt Sander Grinder Jig *LINK*
>This jig belongs in the hand tools section in spite of the jig(s) being (horse) powered since they are designed for chisel and plane blades.
What is involved is the adaptation of a bench belt sander for grinding blade bevels.
I built Mk I version nearly three months ago, and have recently completed MkII. The first machine is easily made by the average woodworker, the second one also but does involve (simple) metal work. Essentially the same jig, although Mk II is an improved design. If you take the time to read (at least some of the posts to) Mk I first, you will understand why Mk II came to be built.
The advantages of this jig are:
1. Firstly, it is cheaper than a Tormek (at 8 times the price of Mk I in Australia).
2. It runs cooler than a Bench Grinder and you have to be a complete Klutz to burn a blade.
3. You can grind a flat bevel as well as a hollow ground bevel, and the set up for either takes a few seconds.
4. The wide belt grinds the entire blade evenly, unlike vertical wheels where you must move the blade across them.
Note that the grinder is to establish the primary bevel, and secondary bevels are honed with waterstones. Having said this, I find that I can now sharpen chisels here sufficiently well to not need anything further (note that this is only after stropping with Veritas green rouge on the �Honing Plate�, which is incorporated into the design).
The following are links to the Australian Woodworking website where I originally posted the designs. The picture posted below is that of Mk I.
Mk I: http://www.woodworkforums.ubeaut.com.au/showthread.php?t=14908&page=1&pp=15
Mk II: http://www.woodworkforums.ubeaut.com.au/showthread.php?p=135269#post135269
Honing Plate:
http://www.woodworkforums.ubeaut.com.au/attachment.php?attachmentid=6561
For further discussion on the use of belt sanders as grinders you can visit Brent Beech�s website: http://www3.telus.net/BrentBeach/Sharpen/beltsander.html
Let me know what you think (if you suffer through it all!).
