Sharpening hole saw
Matt -- Los Angeles
>My 4" hole is dull. It's more like a firestarter than a cutting tool. Can I sharpen it with a file? How so?
Thanks in Advance
Matt
Sharpening hole saw
Matt -- Los Angeles
Thanks in Advance
Matt
Re: Sharpening hole saw
>I don't see any reason why why not. Note that some of these saws are bi-metal which may render the attempt futile with a file.
I wouldn't worry too much about technique. They're not exactly precision tools. So long as they cut who cares.
>There is a technique also (I forgot before I hit the post button) that will reduce the problems.
I score the piece to be cut with the saw then back off. Then I drill a through hole on the circumference of the cut with a reasonably large bit. This gives the swarf somewhere to go and reduces the burning somewhat. You will have to blow it occasionally as it will fill up.
Bob Hutchins in central Texas
>Howdy Matt!
In Leonard Lee's book, "The Complete Guide to Sharpening," he says to sharpen hole saws just as you would a rip saw. (He covers it in the section on drill bits.)
If you don't have this book in your library, I join a host of others in recommending it highly. I've learned more about sharpening more different tools since buying this book than in 5 decades before.
HTH
BobH
thanks fellas...I'll try it
Matt -- Los Angeles
