making round plane sole-easy!
bill tindall
>As you recall I needed a plane to gently curve the inside of a curved door frame.
I occasionally attend the local turning cub meetings. They are mostly artists and turn art. One demo was off-center turning which made some strange stuff, but I filed the technique away. Well, the "light bulb went off as to how to make the plane sole a perfect radius of any desired diameter, Just mount the plane off center in a lathe. My apprentise called in sick so I could not use the manual lathe and was forced to the alternative. I did however resist the power cross feed.
As I thought about it, this approach is just too obvious to any turner that made cabriole legs. So I wonder if this was not the way the "master" planes would have been made. It sure is a very fast, precise way to get a radiused bottom.
Re: making round plane sole-easy!
Steve Knight
>cool too bad I hate lathes (G) but lets see you make a spoon bottom that way thats the challenge (G)
John K in Hastings, MN
>I figured once the planemaker had the hollow, he'd make the round from that plane and vice versa. Make one with any method and the rest with the original planes.
John
Alan Bierbaum
>Thanks for a neat solution. I will file this in some remote brain cells in case a similar problem comes up for me. Thanks for sharing.
>Kewl, but...
Not any radius will work this way. Ar larger radius, yes, but if you go too much smaller, you start taking wood off the top of the plane as well as the bottom. Of course, you could use a milling machine, and cut longitudinally, rotate incrementally, and cut again.
paul womack
>I guess the maximum sole radius is defined by the swing of the lathe.
Larger radii could be achieved by a "virtual circle", the same way the boat builders make giant circles with 2 laths.
BugBear
Bob Hackett
>The hot set up then would be to make them in pairs.If you`re cutting both sides of a wide board then everything is balanced and will run smoothly.
MB
