My illegal spoon.
My illegal spoon.
My illegal spoon.
David Hammond, in Powder Springs GA
>I confess up front, my spoon is illegal, and I'm a partial heretic - I used a couple of power tools... But, it's still a spoon, and I had a great time working on it, so here it is.
I caught wind of the spoon threads a little late, and I didn't think I'd have the time or tools to make one, but I got a wild hair tonight and had a go at it. This is a chunk of Beech I just ripped from a log, in the rain behind my shop, in the dark. I grabbed up every tool I thought I might use, and laid them out - the vise top right is the one I used to hold the spoon as I hacked at it. I ripped the log into a square block on the BS, because I don't have any hand saws, then drew my shape and cut it out. From there I used whatever worked: spokeshaves were helpful (my 51 was canabalized to a slight concave shave, which was helpful), a small turning gouge that I reground, a woodturning half round scraper, drawknife, and my marking knife - then, I confess, I used my electric drill to do some power sanding, then some hand sanding, I put a little Watco and wax on it, and called it done.
David
Re: My illegal spoon.
>Here's my spoon after an hour; pretty rough, but I think I got the general idea. I was stuck hollowing the bowl with a tiny 1/4 turning gouge that I "modified" the grind on - I think a larger gouge would have been rather helful. I have much respect for you guys making spoons that look nice in an hour - an hour just ain't very long! :o)
>And here's the finished product, after close to two hours, some band saw and power sanding help, and some oil.
Drive by gloat - the awl and marking knife are ones I made from same really cool hickory that I got for free (the blade on the knife is an old saw-zall blade, and the awl was an old motor housing bolt); the hickory is lovely dark stuff that polishes up wonderfully. The little marking knife was a big help in carving on the spoon.
Thanks for looking, even if I did cheat. :o)
David Hammond - thinking that I like making spoons...
>Last one - this beech has been sitting in my log pile for some time, and I got a bit of spalting on the backside of the bowl; kind of an unexpected bonus for picking my timber in the dark. :o)
David
Steve Knight
>looks very nice. nothing wrong with a bit of power sanding. think them old timers would not use power sanding if they did not have it? (G)
>Nope, I reckon those old timers might have killed for an electric drill and a few sanding pads - I just didn't figure tailed apprentices were included in this contest.
David
Steve Knight
>if you need to sand those new sanding discs work great. they are a flat piece of paper with slits in them and a bunch bolted together. they don't relaly change the shape of curves but sand pretty well. I used them for a bit.
Nice lines
Greg Betit, Crown Point NY
>I wish I had your eye for style, that's pretty classy.
Greg
Re: Nice lines
>Very nice looking spoon David. Good show!
When's breakfast? ;~)
Todd O.
Re: Nice lines
>Not 'till now, I needed to sleep in after my late night last night! Pancakes sure sound good, but there's leftover pizza in the fridge...
Thanks for the comments Greg - it was easy to come up with nice curve, since I didn't have to worry about cutting it out with a hand saw!
David
Pam Niedermayer - Austin, TX
>Beautiful, David. Since several are starting with milled board, I think using a bandsaw for prep is probably OK (although certainly not as much fun); but it's that pesky drill sander at the end that would disqualify. If only you'd dragged that sandpaper by hand ...
Pam
>If only... Yeah, I would have liked to use just hand tools, but I was over my time limit by a good bit, and my hand tool arsenal is very small - I couldn't make the interior of my spoon cooperate very well with a 1/4 full radius turning gouge and a 3/8 round turning scraper... Oh well, next time!
David
