Chisel Handles
Chisel Handles
Chisel Handles
dave caudill
>After not having a garage for a while I have been catching up on tool maintenance. Cleaned and sharpened some saws, now its time to get to all the chisels that I have been stockpiling. Not much to tell you about but I made a bunch of handles and thought I would show off a little and put some pictures here for everyone to see. Nothing special but its fun to take a chisel that hasn't got a handle and turn a new one for it. The four on the left are made of apple that I salvaged from a friend who was trimming an apple tree. Apple is wonderful to turn it is much like boxwood in how it turns. Very smooth and as I lie to say tunrs like butter. The others are made of hickory that a friend sent me from Illinois. Now Hickory turns different than the apple. Not nearly as tight grained. Much more porous like oak or ash. You don't get nearly the nice smooth finish you do with Apple but they still are nice handles.
I don't turn with anything in mind I just turn and see what happens. They're baically fashioned after other handles I have. I try to size them somewhat commensurate with the chisel size. And most of all I want them to feel good. As you'll notice I don't do leather rings on the tops of most of them. Apple and hickory are pretty good at taking blunt trauma so to me it wouldn't add much other than time.
Dave
Re: Chisel Handles
Nice looking handles...
Scott Burr in Ben Lomond CA
>Dave. I'd say you did good. Did you put ant finish on them?
I need to get a lathe one day...
Re: Chisel Handles
Re: Chisel Handles
dave caudill
>Another picture of handles. These are Indian blackwood I believe. The pieces I use for these are offcuts from Gilmers in Portland Or which has big barrels full of them. Supposedly they are offcuts from someone making musical instruments.
This stuff is different to turn. It likes to splinter and chip, very dense. You have to have sharp tools and take minimal cuts. It does finish up nice and sands real nice. It doesn't really need a finish on it as it is very dense and it seems to have a lot of natural oils. I only know this because I did finish one and it took forever for the finish to dry.
I wish the picture were better quality but by the time I compress them to the required size of 40kb they loose their sharpness. Anyone have any suggestions?
Dave
Re: Chisel Handles
Re: Nice looking handles...
dave caudill
>Thanks Scott.
The one on the very left is unfinished just to kind of show the difference. The rest I just had a can of Formby's Oil/Varnish finsih and just slop a few coats of it on them. Works pretty well. I don't try to get too fancy or caught up in it as they are just working chisels.
You know Scott I just watched and waited until I saw a decent used lathe turn up. It cost me $300 and is a 1965 Delta that is pretty basic but is great for things like handles table legs and an occaisional small bowl. I thik the tools and other things to make it go cost more than the lathe.
Some days its just fun to go out to the garage and start and finish something in the same night. I got to where I was turning these chisels handles out pretty darned fast.
Dave
Re: Chisel Handles
Re: Chisel Handles
Ernie Miller Topeka
>I need about a dozen or so just like them. As soon as you get mine finished some one else will want so so why not spin out a gros or two and put them up for auction. Nice work. I need to be doing that same thing.
Re: Chisel Handles
I am with Ernie.
Wendell @ Murphy, TX
>I'll take two Apple handles please. I can send the rough socket size if you need. :)
Nice work!
Wendell
Re: Chisel Handles
Re: Chisel Handles (Needing as well)
dalfollo
>I can see the need for a set of socket chisel handles...consider truning some for profit!
Re: Chisel Handles
Re: Chisel Handles
Pam Niedermayer - Austin, TX
>How do you compress the photos? I use Photoshop and save a copy for the web, at which point Adobe throws me into ImageReady, where I can adjust several aspects to get it small.
Pam
Re: Chisel Handles
The problems is...
Bob Hackett
>In order to get a good fit you have to match the handle to the socket,which means you need the chisel in order to fit the handle.
Mainely,Bob
Re: Chisel Handles
Buzz off Bob.............
>Dave,
I'll take a dozen of them there Black Indianwood handles. Best get my order in before the line gets too dang long eh? Real nice job on all of them handles Dave.
O.K Bob, Buzz on. ;~)
Todd O.
Re: Chisel Handles
Re: Chisel Handles
Stephen Dalfollo-Daley
>somehow I knew I would hear from Pam, if the post mentioned chisels...even if the comment wasn't exactly on topic.... :)
Re: Chisel Handles
Re: Chisel Handles
>It was on topic for Dave. He asked how to compress photos while maintaining quality of the image.
Pam
