My Grandfather's Stanley #3 *PICS*
John Weber - GO BUCKS!
>Hey guys, as some of you may have noticed I�ve sold off a lot of my older and other planes, never fear, I�ve replaced them with plenty of new iron. I did keep one. Several years ago my Dad gave me my Grandfathers Stanley number 3 � it got me started on number 3�s, but that is another story. Anyway, I believe it is a war time type 17. I�ve left it as is for many years, but recently decided it deserved to be a user. So I cleaned it up a bit, nothing like a complete overhaul Terry does, but a general spit shine and polish. I stripped the knob and tote, hoping for rosewood, but the grain differed in both pieces and the tote was very nondescript. At first I thought I would get a set of replacement pieces, but then thought I should stick with the originals. I thought of paint, but didn�t think that would give me the feel I like, so I experimented with an ink dye and then finished with a satin clear spray topcoat � they feel wonderful. The rest of the plane cleaned up fairly easy. The sides and bottom polished fairly nice, although I should do a little more work to really bring up the shine. The bed had a light over spray mist and that easily came off with a little mineral spirits and steel wool and left a shiny original finish. Cap lever, frog and other hardware all cleaned up nicely. So here it is, my Grandfathers #3, I hope he wouldn�t mind a few changes (like a new Lie-Nielsen A-2 iron). It should be a good user and be ready for my Grandchildren. I do have one problem with it though, one of the frog screws is striped, any thoughts on repair? I assume there are several options, but not sure what people have had success with in the past. Thanks for looking.
John
The before pics:
The after pics:
Re: My Grandfather's Stanley #3 *PICS*
Joe Rogers, Northern Virginia
>He would be proud that you of all his decendants got that plane.
Is just the screw stripped or is the sole boss stripped? Or is it a different fastener than the two sole to frog screws?JR
>Joe,
First, thanks! I didn't realize it was stripped until I reassembled it tonight, and I just assumed it was the boss, but after your post I disassembled it and it is the screw. So now I just need to find a new screw and I'll be good to go.
Thanks again - John
>John that is the best outcome you could have discovered. Any other part damage would have been much harder to fix.JR
Gerald Doll
Looks Great
Gerald Doll
>My bench has 4 planes sitting on it in need of the same TLC. What did you use to polish it, and can I send you mine for the same treatment?
Gerry
looking for the easy way out
Jim DeLaney, Austintown, Ohio
>Usually, (but not always) the WWII planes had a hard rubber adjuster, instead of the brass one.
Also, they were usually missing the frog adjusting screw - neither the frog nor the base were drilled/tapped for the adjusters.
>Jim,
Thanks, I've been informed it's a type 18 most likely. I must have read the chart wrong.
John
Re: Looks Great
>Gerry,
Thanks, I mostly used a red rouge felt buffing wheel, and a little wet dry sand paper. The buffing wheel keeps most of the mill marks, but gives a nice finish. I don't really like cleaning them up - the buffer is dirty and messy, but I do know 3 guys that refinish planes for around $20 I think. Let me know if you want contact info.
John
I think your Grandfather...
Scott Burr in Ben Lomond CA
>Should be proud of you. You did a nice job on it.
What did (or how did) you strip the knob and tote?
Also I probably have a frog screw floating around here. Let me know if you need one.
Re: I think your Grandfather...
>Scott,
Thanks! I just used regular chemical striper. On varnished wood you just need to rinse with mineral spirits, sand, and it's ready for finish. But the paint made the wood a bit blotchy as well, so another reason I when back to black.
I think I have a line on another screw, but if that falls through I'll drop you a note.
Thanks again - John
John Snyder, pocono's
>I love restoring old planes ... nice job !!
