Two Questions
Two Questions
Two Questions
Rob in Kansas
>Last weekend I went down to take my 94 YO Grandfather out of the house for the first time in a several months while we had some good weather. While out I saw what looked like a good sized burl from across the creek. I'd hoped it might be walnut, but I couldn't tell from where I was.
I spent the day with him again today and while he took a nap I slipped out to take a look. Found out it was a cottonwood burl. Hard to get a good estimate as it was 10 feet up, but I think it was about 10"x18"x24". Anyone ever use any cottonwood burl? How does it work?
Also, in the old farm house that is starting to fall down is one of those old wood cook stoves that has what I think is white and pale green enamel on it. I�d been thinking I needed to try and get it out for quite some time, but today I see where on one door someone must have shot it with a pellet gun and broken part of the enamel. Anyone know if the enamel can be repaired? I thought it might be nice to give it to my mother for Mother�s Day. It would go well with my great grandmother's kitchen "cabinet".
Re: Two Questions
Re: Two Questions
JL work
>Enamel can be patched/repaired fairly easily. The problem is matching the color. As to cottonwood burl - I have no idea. I haven't worked any cottonwood. I would think that it would be relatively "soft" and fuzzy to work.
Re: Two Questions
Re: Two Questions
Ernie Miller Topeka
>I have a cotton wood 4X4 here at the house if you want to come get it and play with it to see how it works. it is a fuzz maker. burl could be fun.
Re: Two Questions
Re: Two Questions
Rob in Kansas
>Thanks JL, Is patching enamel something that is commonly found or is it more of a specialty? I guess I should have done something last year. I'm pretty sure it was okay then. :(
Ernie, I've never worked cottonwood before, but I have been told that the southern basswood will cross pollenate with the cottonwood and that's what causes it to be fuzzy. That kiln in Perry process cottonwood and sells it primarily overseas as a secondary wood.
Re: Two Questions
Re: Two Questions
JL work
>As I said, color matching is a problem. You can buy the filler kits over the internet or at some local hardware stores. Brush a little dilute HCl (muriatic acid) and eat the rust away - or get a rust converter compound. You can then fill and paint. I had to do it on an old washing machine (wringer type), fortunately it was white. It took a while to match the color exactly.
Re: Two Questions
Re: Two Questions
Rob in Kansas
>Thanks Jim & JL,
I found this photo on the net, which is the basic shape. (They want $4850 for it!) But the gray part is white/ivory and the white part is pale green. It has about four spots on one door that need to be filled in, the rest appears to be okay. I managed to get the name of someone in Lawrence who does bathtubs. Maybe he can do a door as well.
JL what did you use to adjust the color on yours?
Re: Two Questions
Re: Two Questions
Roger Nixon
>Interesting, Rob. I spotted a big cottonwood burl on a neighbor's property two weeks ago and wondered the same thing. Not that I would tackle that tree for the burl.
Re: Two Questions
Re: Two Questions
Rob in Kansas
>I did a search and found a couple good pics. I don't plan on harvesting it anytime soon. I'll at least leave it until my skills are better, or the creek threatens the tree. A couple years either way. I can see where it would make some nice panels, might even try turning!
You move closer to town yet?
Re: Two Questions
Re: Two Questions
>Remember, I was going for a "duller" white as opposed to anything else. I used a touch of black and gray pigment.
