A55 Smoothing Plane
Lie-Nielsen Question
dave in texas
>Does anybody out there have any comments on the Lie-Nielsen low angle smoothing plane?
And can it be used as a jointing plane also??
Thanks
Dave
Re: Lie-Nielsen Question
Dean J in MN
Do a search here for 'low angle' and you'll have enough to read for a while! Having said that, it is a fine tool, and even flexible in regards to effective cutting angles...
Mmm, well, that is difficult to answer. If you mean jointer in the sense of plane used to prepare long edges of boards for a glue joint, then I'd say there are much better planes for the task. For one, the LA smoother is rather short for a jointer (unless your boards are really short) and also, most smoothers have a convex blade and a jointer has a sqaure blade.
If you mean jointer in the sense of a longer plane used to bring a face or edge square and/or flat (i.e. a try plane) then my advise is, if the boards are really short, sure. A try plane has a convex edge, so would your smoother and in a pinch you can use your smoother as a sort of try plane.
But then you wouldn't have an excuse to by anther tool!
-Dean
I love mine...
Scott Burr in Ben Lomond CA
>It's a great plane. Lots of others like the LV one, but it's too ugly for me.
As said there's been a lot of talk about these lately.
I can't recommend it as a jointer. It's too short; it might work well on short pieces, but not on long boards.
