? on custom pricing
? on custom pricing
? on custom pricing
Dale Lenz-Tahlequah, OK
>I have an inquire about building a flag case out of birds eye maple. I can figure the "extra cost" for bird�s eye maple over "normal" lumber.
My concern is over, the degree of difficultly/extra time, working with bird�s eye maple, I have never worked bird�s eye maple. I have always heard horror stories of working bird�s eye, i.e. tear out etc. I do hand plane, joints, and scrape alot of my work.
My question is: How much extra in "percent" would you charge for working bird's eye maple, 15%, 25% etc. Once again, please do not include extra cost of the bird's eye lumber in the extra work involved with bird's eye maple, only the extra work/time involved. I will attach a pic of a walnut flag case if needed for your estimates.
TIA,
Dale
Re: ? on custom pricing
R.J.Whelan
>Dale ... if you have a high angle smoother (York or higher), and keep the throat closed right up, and set the iron for a very shallow cut you shouldn't have a lot of trouble. Giving the timber a coat of 1# cut shellac before planing will help control tear out.
If you don't have the above described plane I'd probably suggest sanding and light scraping. A plane not up to the task can cause a lot of damage that'll take quite a bit of work to correct with sanding and scraping.
Good luck with your project.
BTW - if you plan to dimension the timber with an electron eater (planer) I'd suggest very light passes and wet the surface of the wood before each trip through the cutters.
-rj-
Joel
>Why don't you take some birdseye and try planing it. Practice is always a good thing and it will give you an idea of what you are in store for and what the extra cost will be for your methods of work.
Patrick Gibbons, Space City, TX
>Wetting the wood has worked very well for me. I do not use water. Mineral spirits is best. It doesn't raise the grain and doesn't rust your tools.
Re: Thanks to all...
>I will proceed if the customer accepts my offer. I like the mineral sprit spraying idea. I was wondering about the rusting problem...Dale
R.J.Whelan
>Should have mentioned that - I, too, use mineral spirits .. rj
