A55 Smoothing Plane
Electrolysis using computer power supply
Matt Williams Marysville WA
>I would like to use an old computer power supply to zap some planes clean.
I was also wondering if you guys that use electrolysis all the time have found that screws come loose better after zapping or if you need to get them all free first?
Thanks.
Re: Electrolysis using computer power supply
Dan Clermont in Burnaby
>Hi Matt,
I've used a wall wart and it was fine. Took a little longer then a trickle charger.
I would think that the screws would loosen if they sat in an electrolysis tank for awhile.
Good Luck and let us know what happens,
Dan Clermont
Jack Guzman from Maine
>I've found that if there aren't too many threads deep in the object they'll free up.The process works by line of sight. The part you want to derust has to be facing and exposed to the sacrificial piece.
I'm no expert but I do alot of electrolosis.
Jack
David Miller from Iowa
More Specifics please
>THere are several leads off the power supply. Do you just chose a positive and negative and hope it isn't too "hot" or is there some easy way to tell. Any idea if I'm going to cause a short circuit or if the power supply will die after a while?
Ernie Miller Topeka
>Let me look at this picture Computer power supply several leads off one machine? would a person be able to set it up so that there are electrodes on several sides of an object at the same time? Some one smarter than me needs to look at this
X-ZAPPING this sounds like a Todd O project master zapper. I don't do much zapping any more if it is that bad I don't bring it home or if I do I sell it and let the new owner mess with cleaning.
Re: Electrolysis using computer power supply *LINK*
Dan K
>Here's a site with a good article, they use a battery charger
http://antique-engines.com/electrol.asp
Re: ????
Tom MacGregor, Vermont
>I've successfully removed rust from both sides of an object with a trickle charger. I bolted two pieces of iron together with threaded rod to make a big upsidedown U. I clamped onto the rod- which was above the waterline- and both pieces of iron stuck in the soup gathered rust from opposite sides of the tool at the same time. I'm going to try a piece of stovepipe and see if I can get 360 degree removal.
Would that be Dell or Compaq?
victor P
Re: More Specifics please
Dan Moening in foggy Sacramento
>The leads (+/-5, +/-12) used to be color coded (and maybe even pin specific) IIRC.
I would have to blow the dust off my A+ Cert manual to be sure...
I'm sure someone with a better memory will chime in...
Dan.
geat idea
>Thanks for the idea. That's one thing that bugs me is only getting oe side at a time.--Jack
Mac of course - what better use is there for a Mac
Greg Sloop, Portland Oregon
Re: geat idea *LINK*
walt quadrato
>here's another take on the same idea..I "borrowed" my wifes large stew pot....24" deep...poured the "soup" into the pot..connected the positive to the pot handle (using the whole pot as the electrode)...the negative to the plane body which was hung as close to dead center as I could...plugged it in and within 10 minutes had very warm soup and a clean plane...she took the pot back when she found out about my experiment and banished me from the kitchen for 5 years...I think it drew close to the maximum amps...I've been looking for a resturant pot..3 feet deep and 2 wide at the fleas ever since. of course with no luck...
walt Q
toolworks
Re: ????
Doug Littlejohn
>I use four pieces of rebar standing vertically. Then I tie all 4 together with a piece of 12 gauge copper wire and attach my electrode to that. It give me pretty much all sides at once, though not perfectly even, but more than good enough so far.
Sherwood.
PS - I would loosedn the screws first and then clean out the gunk. Electrolysis won't work on the greasy/dirty areas, they need to be cleaned first. If you do it without loosening the screws, you probably won't get the rust out from around and under them.
Angelo in Cornwall, NY
>Been toying with this idea for a long time. I do know that if you short or overload a powersupply (like by plugging something in backwards) its toast. DAMHIKT. The specs for an "universal" no-name power supply are:
Orange - "Power Good"
Red - +5VDC
Yellow - -12VDC(on connector P8)
Blue - +12VDC
Black - Ground
Yellow - -5VDC (on connector P9)
I know that newer power supplies have +3.3VDC too. I would get ahold of a multimeter, check the voltages, and start with 5V DC. I might give this a shot myself tonite and see what damage I can do as I have an unlimited source of power supplies.
It works!
>It works, at least using 2 of the yellow 12V leads and one black ground. Bubbles kinda slow, even compared to my 4 amp charger. If its still alive in the AM, I'll rip it apart and solder on thicker wires, hopefully it will improve the amperage getting to the rust.
Get a Mac to replace the defective Dells & Compaqs
Eric Hedberg
I'm definitely gonna try that one!
VERY CAREFUL !!!!
Fred in NC
>There is high voltage and capacitors inside a computer power supply, EVEN after you disconnect from the power. I would not do that!!!!
Just take two or three blacks and same number of yellow, and bunch together. They are connected to the exact same spot inside.
By the way, computer power supplies use a switching circuit. Most of them will not supply a full 12 V amperage unless the 5V side is also in use. I would try a 6V light bulb across one of the 5 V connectors. All it takes is a little bit of drain.
Re: If you prick us, do we not bleed?�
>The Leachmeister likes to bash #6s and to recommend transitionals for their BTU value. He offers some rationale for his opinions. My favorite whipping boys are the Stanley #75, and its Kunz knock-off, which Kunz couldn't manage to make any more dysfunctional than the Stanley. We have discussed the reasons these planes have shortcomings, and their viable alternatives.
Some of us do pins first; some do tails first. Some prefer to saw on the push stroke; some prefer to pull. Some like the advantages of wooden planes; others prefer metal. Some bevel up; others bevel down. We offer, and thoughtfully consider, reasons for and against our choices. You are always welcome to offer rational commentary on the relative merits of PPC/MacOS vs. Wintel platforms, but a little more objectivity than a rhetorical, disparaging *NM* would be appreciated by all those who come here seeking, or offering, valuable advise.
I find the Mac to work quite competently for woodworking, and for web based woodworking support, and even for hand-tool woodworking, with one minor exception -- it has a propensity to kill electrons, just like Wintel machines. There is nothing that a PC can do that a Mac cannot, and vice versa. "It's all ones and zeros." Many things, due to hardware acthitecture, OS, philosophy, and SMOP, the Mac does better, some things the PC does better. When ergonomics are considered, the Mac has a clear, demonstrated advantage. OTOH, If you compare total IT support salaries vs. the useful work performed by the supported users, the PC clearly wins. I'm not about that. If I were, I wouldn't be providing free advise and support to WC.
I own and have owned and used Macs since early 1984, (I'd rather not be reminded of when I bought my first DOS machine, but I own several of them and their spawn as well.) and have programmed, supported and maintained Intel/IBM/�soft machines, and designed and developed systems based on both platforms, and several other computing platforms, beginning in 1966. I have used PCs out of economic necessity, but Macs by choice and what is, IMHO, just plain common sense.
Addy protocol: BS CS FIT '75, ~30 years computer science and engineering experience in process control and telecommunications. Retired DMTS, Systems Engineering, Siemens Telcom. Also, FWIW, I'm a professional cabinetmaker.
you need current
bill tindall
>I don't know the wattage of a computer power supply but it can't be competitive with a battery charger. When it comes to electrolysis, more current is better/quicker. Lots of bubbles cleans better too. Electrolysis is not "line of sight" it just seems that way with weany power. E=IR. The solution supplies resistance. So the farther away, the lower the voltage, and the slower it goes. This is why backsides go slow.
Just use a battery charger.
>WD: Just yanking the Mac'ies chains.
Frankly, I love the Macs, even though I don't use them. I have a love hate relationship with the predominate OS on the PC - namely Windows.
It supplies the bulk of my income, but really is a terrible dog. (And that's being unfair to even the meanest junkyard dogs.)
Macs, while the hardware is overpriced and seems to have a propensity to design fluff has a very nice OS. They're a computer for the guy who simply doesn't want to worry about what is going on underneath the surface, but wants quality.
Windows is for those who want pretty, but are willing to buy trash on the inside as long as it's pretty on the outside. (Sorry, I'm part of that group too, so I'm dogging myself as much as anyone.)
Unix is for people who don't care how butt ugly it is, but it must be really done right and seriously functional. However it appears, it's not a real requirement that it be way too complex and user-unfriendly.
So, in short, I love bugging the Mac folks. But when asked about them, generally say I love them. If you can live with the software available for them - which won't be as plentiful and as cheap as that for Windows - you'll probably love em.
But they (the users) wound so wonderfully, and with such elegance and style, I can rarely pass the opportunity to inflict one every so often.
Cheers,
Greg
Wolfgang Jordan, Munich (Germany)
>I've cleaned a lot of plane irons and never had to turn one around to derust the back side. I'm not sure if this line-of-sight thing is true. It may give slightly better results, though.
Wolfgang
Re: low current recommendation
paul womack
Certainly quicker.
This guy has "an opinion" on better.
detailed Electrolyis information
I have no idea if he's right, be he seems to have looked into the issue in depth.
BugBear
>OK, I'll forgive you. Just remember, it's not nice to pull people's chains, unless you're going to help them out after you've gotten their attention. Otherwise you just make them angry, increasing polarization, and decreasing the likelyhood that they will learn anything in the future. Also, on a public forum, yanking tends to upset lots of people other than the intended victim.
